Torque Values Consulting The CorvetteForum Oracle
Old Feb 3, 2023 | 04:51 PM
nitromainia's Avatar
nitromainia
Default Torque Values Consulting The CorvetteForum Oracle
Just finished the Balancer Install and Dialing in the Cradle to Frame
Hoping someone has a link to these values or a good number...
I Couldn’t seem to find a value for the Lower Engine mount to the Cradle
And the Steering Bolt
Thank You!!
Save the Wave
Old Feb 3, 2023 | 04:58 PM
Smoken1's Avatar
Smoken1
This should have what you need
File Type: pdf
Old Feb 3, 2023 | 05:56 PM
nitromainia
Yes, Thank you! However, I cannot find the Steering Coupler Bolt Value
Nor the Engine Mount Lower Nuts as the stud passes thru the Cradle...
Unless I don’t recognize the name? Seems it’s not on this Spectacular List?
Or Am I going Blind?
Old Feb 3, 2023 | 06:51 PM
Smoken1's Avatar
Smoken1
Where the lower clamp slides on to the steering gear shaft. The torque spec is 25 lb ft
nut from under the car/subframe is 48ft/lb.
Old Feb 3, 2023 | 10:41 PM
nitromainia
Bang! Got it.. Thank you!
Save The Wave!
To Torque Values Consulting The CorvetteForum Oracle
