I'm guessing my MAF has never been cleaned. The car is running fine, no issues. Should this be a regular maintenance step or only if there are issues? Thanks!
This is more of a "piece of mind" issue for yourself to wrestle with. People will argue that cleaning the MAF should be a regularly maintained item while others go their entire ownership period without issue or a second thought.
Now, I did clean mine. No for any other reason than I was bored and needed a no stress project. I was able to make a 15 minute task into 90 minutes by over engineering cleaning, inspecting tightening....etc and with the aid of a couple of beer.
LOL! That's where I'm at. Just looking for another project on my car. It surely can't hurt? Thanks! PS. I see you are in Southlake, We aren't far apart. I live in Paradise.
A MAF and Throttle Body cleaning every other year would be a good preventative maintenance task…cleaning grounds on the outside of the car wouldn’t hurt either.
I agree. Whenever I take off someone's MAF for whatever reason and im about to tune it, I spray it with MAF cleaner.
Very carefully use an electrical spray contact cleaner and a Q-tip. Very gently run across both sides of the wires. I do that about every 25k miles because I use a high flow / oiled filter. Maybe 25% of the time I notice a better idle (when there is clearly a dirty wire)
