Electronic Brake Control Module (EBCM)
Feb 11, 2023 | 12:53 PM
If the 1997 - 2000 EBCM fails and cannot be fixed or replaced, will this cause state safety inspection failures?
If the EBCM fails, I believe the traction control and active handling stops working. ABS still functions though. Please confirm.
Thank you in advance.
Feb 11, 2023 | 01:19 PM
Quote:
Originally Posted by
silverja
Check ur state . Got lucky in IL
Feb 11, 2023 | 01:30 PM
Disagree on the ABS still functioning. Lucky my state doesn't have inspections.
Feb 11, 2023 | 01:31 PM
silverja
Yes.
You lose all 3 ABS, TC and AH.
Feb 11, 2023 | 01:35 PM
Thank You
ThomasR
Yes.
Ouch! Thanks for the reply. Will avoid 2000 and earlier C5's.
Feb 11, 2023 | 01:37 PM
Thank You
wrmiles
Thank you for the clarification on the ABS not functioning.
