Steering Wheel Removal HELP
Old Feb 15, 2023 | 09:59 AM
KRPTONT's Avatar
KRPTONT
Default Steering Wheel Removal HELP
I have a 99 FRC and I had a custom steering wheel made. My performance shop has tried 3 puller and it won’t budge. Does anyone have any advice for the removal? Tricks or other solutions???
THANK YOU IN ADVANCE
Old Feb 15, 2023 | 12:36 PM
OneFast1's Avatar
OneFast1
I tried removing mine with a socket wrench and had no luck, it even broke the puller.. I took the car to a shop and they used an air impact and it popped right off. Maybe it's the shock of the impact that works?
Old Feb 15, 2023 | 01:29 PM
johnson-rod's Avatar
johnson-rod
Couple of drops of PB Blaster on the splines the night before.
Old Feb 15, 2023 | 08:25 PM
heggsc5's Avatar
heggsc5
Just like pretty much anything you use a puller for, tighten it pretty good then tap the object you're trying to pull several times, tighten again, tap again, tighten again, yada yada. I seem to be one of the "lucky" ones, but mine popped right off after a couple rounds of doing that. There have also been folks that have had to rip the whole steering column out to swap it, soooo...best of luck!
Old Feb 16, 2023 | 10:39 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Sounds like you've got one of those demon wheels.
Pics of your new custom?
Old Feb 16, 2023 | 07:52 PM
Dads2kconvertible's Avatar
Dads2kconvertible
Apply penetrating fluid, give it a few minutes, tighten puller securely, not super-duper tight. Hit puller bolt several times with large hammer. You have to provide enough shock load to break the existing bonds. Many smaller hits rather than one big one that breaks stuff.
Heat works for some applications but I think the 'vette has vulnerable plastic pieces so unlikely to be an option for you.
Old Feb 16, 2023 | 08:13 PM
EZ Glider's Avatar
EZ Glider
Like anything there is a special puller for this. I bought one but cant get to it now as I am moving and it's packed, but the arms look like this...
https://www.autozone.com/loan-a-tool...ler/787836_0_0
It worked great.
To Steering Wheel Removal HELP
