Help please !!!code 10-pcm p0327
Old Feb 20, 2023 | 11:21 PM
Organic5's Avatar
Organic5
Default Help please !!!code 10-pcm p0327
Just got the code for faulty knock sensor, I cleared it and car drives normal again , however upon startup the car has hard starts , it will start on second turn of key but the idle drops almost as if it’s going to shut off, but then the idle jumps right back up to normal , this problem is on every startup . Any help would be much appreciated . My car is a 99 automatic 4 speed no other codes .
Old Feb 21, 2023 | 04:12 PM
Sideswipe505's Avatar
Sideswipe505
Sounds like you need to replace your knock sensors. Or delete them which would require tuning. Either way, you're going to have to get into the valley cover. I would also check the harness while you're in there.
