Caliper Bolts
Old Jan 13, 2003 | 05:07 PM
rozdesign's Avatar
rozdesign
Default Caliper Bolts
Can you get these anywhere, or is there a strength rating I should be looking for, i.e. GM part?
Changed the pads a few times and the loc tite is starting to build up...
Old Jan 13, 2003 | 05:41 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: Caliper Bolts (rozdesign)
the guide pins that are torqued to something like 30ftlbs....I can't imagine having to replace those often :)
Old Jan 13, 2003 | 08:59 PM
CHJ In Virginia's Avatar
CHJ In Virginia
If you are going to replace them, go with a grade 8 high strength bolt. No use to fool around with inferior fasterers on brakes. Better yet, just take a wire brush in your electric drill and clean the old lok-tite off. Easy and saves the cost of new bolts. If you have changed pads a bunch of times, you might want to take a tap and chase the holes in the caliper bridge to remove the old junk from them.
Old Jan 13, 2003 | 09:30 PM
Bill Reid's Avatar
Bill Reid
I assume you are not using GM pads?... as far as I know all GM pads we have received come with replacement bolts. I don't recommend replacing the bolts with anything but GM part numbers. I don't have the number on me but if you call the shop tomorrow we can look it up for you. Regarding the buildup... like CHJ says, I would recommend running a tap through the caliper bracket holes as well. This will ensure a true torque with the new locktite. :)
:cheers:
[Modified by billreid1@***.net, 7:30 PM 1/13/2003]
Old Jan 13, 2003 | 09:33 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
I take a wire brush and clean the locktite off and reuse them many times. I switch pads a rotors after I race at least 50 times.
Old Jan 13, 2003 | 11:26 PM
Jim 47's Avatar
Jim 47
Default Re: Caliper Bolts (John Shiels)
Yeh, what he said. :iagree:
Old Jan 13, 2003 | 11:41 PM
corvette184's Avatar
corvette184
Default Re: Caliper Bolts (Jim 47)
i just ordered 8 bolts from gm....i am changing to baer rotors and read that bolts should be changed every time....i wouldnt think so be because they arent stretch style????but i got em anyways...better safe than sorry...not too cheap either 5.40 each :yesnod: :yesnod:
Old Jan 15, 2003 | 02:45 AM
Richin Chicago's Avatar
Richin Chicago
The GM part number is 14067559 and they come in an airtight bag with the loctite (red) already on. 40 of them cost me $40.00 deliverd at: http://www.{Non-supporting vendor}.com
To Caliper Bolts
