hurst shifter
Old Jan 13, 2003 | 09:25 PM
magragc5's Avatar
magragc5
Default hurst shifter
I just installed a hurst shifter-- WOW! What a difference. Night and day is the only phrase to describe it. Anyone on the fence- jump in. The throw is so short and precise it is like having your hand become part of the tranny.
What springs do you guys use. I used the two softer ones, it seems to be good in terms of feel and return, but is there anything I should be looking out for?
:D :D
Ed :steering:
Old Jan 13, 2003 | 09:33 PM
Bill Reid's Avatar
Bill Reid
Default Re: hurst shifter (magragc5)
The 2 softer ones really are the way to go... you can also still play with the spring tension for that final tune. :)
:cheers:
Old Jan 13, 2003 | 09:50 PM
GaryZ06's Avatar
GaryZ06
I have tried many combinations but I like the one I have now.....1 light outer spring per side.
Old Jan 13, 2003 | 10:15 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: hurst shifter (GaryZ06)
Factory settings for me! :cool: :cheers:
Old Jan 13, 2003 | 10:18 PM
magragc5's Avatar
magragc5
Thanks guys, I like this setting so far, H/C, gears and LT's here I come!!!! :yesnod:
Old Jan 14, 2003 | 01:57 AM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
I use the two softer ones.
To hurst shifter
