Errr... Help! (PCM Removal)
Old Jan 13, 2003 | 10:26 PM
Johnno's Avatar
Johnno
Default Errr... Help! (PCM Removal)
Anyone that's removed a PCM before, can you offer any advice?
See this link: http://forums.corvetteforum.com/zerothread?id=471472
Thanks in advance!!
[Modified by Johnno, 9:26 PM 1/13/2003]
Old Jan 13, 2003 | 10:47 PM
NEPTUNEBILL's Avatar
NEPTUNEBILL
Default Re: Errr... Help! (Johnno)
The PCM is mounted in a plastic bracket that is a tight squeeze, be careful working it out as the bracket will break, mine broke clean and super glue has held it together fine for over a year, I swore at the time if I ever had to do it again I would remove the fender, tight squeeze for big hands. good luck
Old Jan 13, 2003 | 10:50 PM
Bill Reid's Avatar
Bill Reid
Default Re: Errr... Help! (NEPTUNEBILL)
...tight squeeze for big hands. good luck
I'll second that motion :D
Old Jan 13, 2003 | 11:10 PM
Johnno's Avatar
Johnno
Default Re: Errr... Help! (billreid1@***.net)
Thanks for the tips guys! The forum is GREAT! Wt99c5 mentioned the screw on the other side needed to come out as well - not too difficult with the right socket wrench - I.E. a SMALL one! It popped right out after that. Yep, the space is a bit tight. Glad I posted asking for tips before taking a crow bar to the thing. :crazy: :lol: :D
Old Jan 13, 2003 | 11:13 PM
Bill Reid's Avatar
Bill Reid
:cool:
:cheers:
To Errr... Help! (PCM Removal)
