DIC Issue - Help
Old Mar 8, 2023 | 12:43 PM
ABACUS's Avatar
ABACUS
Default DIC Issue - Help
I have found a few threads about DIC issues, but nothing with my specific issue. The display keeps rotating through the same settings. It's as if someone is pressing the Gages button over and over. Once it starts doing this, I can sometimes hit other buttons but also none of the buttons will respond.
Was wondering if replacing the DIC buttons would be a fix, or is this an issue where replacing the IPC is the only fix. Any help would be appreciated.
Old Mar 8, 2023 | 02:57 PM
sayerbloke's Avatar
sayerbloke
Hmm. Not one I’ve seen myself… could it be a grounding issue? Someone with more experience in such matters will be along shortly to put me right I’m sure, lol. Hope you find a fix soon
Old Mar 8, 2023 | 04:14 PM
rrwirsi's Avatar
rrwirsi
I would try rebooting like sometimes is needed in computers. Disconnect the negative battery cable for about 5 minutes then reattach the cable. Just maybe it will work.
Old Mar 8, 2023 | 08:53 PM
redzg's Avatar
redzg
My '99 has started randomly rotating through the configuration settings. I've found some older threads indicating it requires replacement of the insturment cluster, which seems extreme. I've obtained a spare cluster -- with DIC buttons -- and will first try cleaning the spare buttons and swapping them for the originals. Hopefully it can be found in the button set or ground.
Old Mar 12, 2023 | 05:48 PM
ABACUS's Avatar
ABACUS
I left the battery unhooked overnight and the display started doing its thing as soon as I pulled out of the driveway, so that didn't seem to help.
Old Mar 12, 2023 | 05:49 PM
ABACUS's Avatar
ABACUS
Originally Posted by Vette Millenials
Also check the tightness of the negative terminal. I’ve found this helps.
I made sure the connections were solid and they didn't look corroded either.
To DIC Issue - Help
