Gear fluids
Old Mar 10, 2023 | 04:13 PM
2010Pony's Avatar
2010Pony
Default Gear fluids
Getting ready to change oil/filter and have heard different options on changing manual transmission fluid and rear axle fluid 2000 M6 with 342 axle with 83,000 miles. Manual says never needs it and I have no idea if it has been done, when I’m under there checking levels what should it look/ feel like so I know if I should also do this. Also what brand/weight/amount and do you need to add limiter slip fluid. So many different reading not sure what you all are using. Thanks
Old Mar 10, 2023 | 04:42 PM
Corvette Lovers's Avatar
Corvette Lovers
I’d call your dealer. But Dex 6 is the go to. I change my trans and diff fluid every 25k.
Old Mar 10, 2023 | 07:17 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
Just changed mine with Dex6 at the Dealer
Old Mar 10, 2023 | 07:18 PM
Corvette Lovers
Old Mar 10, 2023 | 07:36 PM
Corvette Lovers
Tremec will never publicly admit, but they also recommend dex 6.
Old Mar 10, 2023 | 09:08 PM
vette4fl's Avatar
vette4fl
Rear gears: Any full synthetic 75-90. I prefer RedLine GL-5 75W-90, which already has posi conditioner mixed in; 3 quarts. Have also use Valvoline full syn with no issues.
Trans: RedLine D4 ATF, 1 Gal
Old Mar 11, 2023 | 07:27 AM
2010Pony's Avatar
2010Pony
Thank you all for the information! What are the numbers on Dex 6 please. Want to check both brands out before buying. Is the Dex 6 only available at the dealer
Old Mar 11, 2023 | 07:34 AM
2010Pony's Avatar
2010Pony
Everything I’m seeing on line the Dex 6 is for automatic transmissions, mine is M6. ??
Old Mar 11, 2023 | 07:42 AM
ThomasR's Avatar
ThomasR
The manual trans cars use ATF. Anything Dex III compatable. It's rumored most synthetic fluids ruin the paper blocker rings in 2000 and earlier cars.
Old Mar 11, 2023 | 07:58 AM
2010Pony's Avatar
2010Pony
Ok thanks, never knew this would be so difficult trying to find proper fluids. And yes this is a 2000 manual.
Old Mar 11, 2023 | 10:07 AM
Supercharged111's Avatar
Supercharged111
You're not the first person to say this, and I don't understand why. The Camaros ditched the paper rings back around 95, why oh why would GM/Tremec then go backwards from there?
Old Mar 11, 2023 | 01:18 PM
johnson-rod's Avatar
johnson-rod
I use Amsoil Torque Drive for the M6 in my 1998.
I use Amsoil Severe Gear in the rear. No additives needed.
I've been very happy with both.
150K and no problems.
Old Mar 11, 2023 | 03:01 PM
2010Pony's Avatar
2010Pony
Ok thanks for all the help
To Gear fluids
