View Poll Results: Replace purge valve on 2000 vette location of valve
Location of purge valve
2
100.00%
Small vacuum leak code P0442
1
50.00%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Getting code P0442
Old Mar 11, 2023 | 05:48 PM
Lpga's Avatar
Lpga
Default Getting code P0442
Where do I find location to fix small vacuum leak on purge valve
Old Mar 11, 2023 | 07:22 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
A P0442 is a "small" vacuum leak which could be a bad gas cap, leaking purge or vent valve or a line in the EVAP system that may have a small leak...diagnostic equipment like a bidirectional scan tool and "smoke machine" is used to find these small leaks....how was it determined it was the purge valve ??..I see your a teaching Pro...a friend of mine back in the 90's was a LPGA tour pro and played on the 1996 Solheim Cup team.
Old Mar 11, 2023 | 07:37 PM
Lpga's Avatar
Lpga
It was diagnosed with a code tool. I cleaned and check gas cap it was fine. It specifically said it was a small leak and showed video of what this black purge valve looked like. However I needed to see where it is located and if the car has to go on a lift. Who was the golf pro you knew. I may know her. I got involved in LPGA in 1990. Still teach sporadically and play alot. Gonna be 75 on June 1st but going strong thank God....
Old Mar 11, 2023 | 08:01 PM
C5 Diag's Avatar
C5 Diag
The P0443 is a purge valve "circuit" code which tells me it's either the purge valve or a wiring issue...the 0442 is just a small leak and the purge valve in the picture is located on the drivers side of the engine as you can see in the pic and can be reached from above...Val Skinner was her name and she retired from the Tour when she developed some shoulder issues...was amazed when we would go to the golf range where we lived and she would just bang them out consistently 250 yards straight as an arrow !!
Old Mar 14, 2023 | 02:08 PM
Lpga's Avatar
Lpga
Ok Got new purge valve. However, I remember someone writing about the little white plastic clips on the hose connection and said he broke them and they can't be replaced. One guy showed a pic of taking a screwdriver and pressing down on it to release the hose. What's the best way to unhook the hose? I knew Val Skinner. I believe she lived in New Jersey back when I played in the Atlantic City Shoprite Classic. I was the person who organized and implemented the Jr. Kids Clinic for that event with the corporate sponsors.
Old Mar 14, 2023 | 03:08 PM
C5 Diag's Avatar
C5 Diag
Val lived in Bay Head about 1/2 mile where I used to live...picture below !!
Old Mar 28, 2023 | 08:20 AM
Lpga's Avatar
Lpga
Purge valve installed and all is well. Thanks for your help. Very much appreciated.
Old Apr 29, 2023 | 02:09 PM
Lpga's Avatar
Lpga
Default Purge valve replaced.
Put new purge valve on. Check engine light coming back on. Have only gotten P0442 code. Have cleared it twice and it comes back on after driving for a few days. Don't know if this valve is bad or something else within evap system is causing this code still. HELP PLEASE!!!
Old Apr 29, 2023 | 02:45 PM
C5 Diag's Avatar
C5 Diag
Well you had a 50-50 shot...it would have been best to take it to a shop that has a smoke machine to let them diagnose it...it could be leaking gas cap, purge or vent valve, any of the EVAP hoses or maybe even an EVAP cannister...these small leaks are sometimes hard to diagnose...these are pinhole leaks...you can try replacing the gas cap if you haven't done that yet....just looking good is not good enough...best to order an OEM cap if you can...was your purge valve OE or aftermarket...anything bought on Ebay or Amazon is suspect.
Old Apr 29, 2023 | 06:00 PM
Dads2kconvertible's Avatar
Dads2kconvertible
I didn't just join today. This is my 9th Corvette and had several different years.I am somewhat knowledgeable however I like to come to the forum to get better advice than spending thousands chasing a problem. Previously on the forum I had gotten this code about a month ago. Checked gas cap and it was ok. Bought a new purge valve because this was suggested. Had no code for a few weeks then got rhe P0442 again. Cleared the code and now check engine is on again and only code I'm getting is 0442. Could be a bad purge valve that was supposed to be new and it is a piece of crap!! You know made in China bull....so trying to figure out how to find this small leak in the evap.
C5 wasn't replying to you he was replying to the scammer @Licious
Every now and then trolls show up on the forums and try various things to cause mischief. They generally get shut down fairly quickly.
Work with C5 on your issue, he knows his stuff and can help you get it solved.
Old Apr 29, 2023 | 06:04 PM
C5 Diag's Avatar
C5 Diag
I called her and she now understands that !!...this has been pretty consistent with only me by this banned member but it's in the FBI's hands now as a case of cyberstalking !!...I've had it !!!
Old Apr 29, 2023 | 06:57 PM
Smoken1's Avatar
Smoken1
Good luck with that...
Old Apr 29, 2023 | 07:00 PM
C5 Diag's Avatar
C5 Diag
Thanks !!!
Old May 6, 2023 | 12:50 PM
grinder11's Avatar
grinder11
Thanks !!!
Hey Rob, how is that FBI investigation going?
Old May 6, 2023 | 01:22 PM
v8srfun's Avatar
v8srfun
When you get sound advice and ignore it you end up spending money on things that won’t fix your car.
Old May 6, 2023 | 01:26 PM
C5 Diag's Avatar
C5 Diag
Hey Mike !!…good…they wanted my Forum username and password so we will see what happens !!…are you back home ??
Old May 6, 2023 | 02:38 PM
grinder11's Avatar
grinder11
Not yet....
To Getting code P0442
