Hello y’all, so I have been fighting with my c5 for a while now. I just put in a new pilot bushing to replace the pilot needle bearing. I also had the input shaft remachined because it got eaten up. the machine shop remachined it to the same specs it was originally at. I know these bushings can shrink some so I had them mill/machine off half a millimeter. It goes in and out fine but there is a little space between the input shaft and the bushing now. Do y’all think this could cause a detrimental rattle? There isn’t hardly any free play at all, just like 1/4 to 1/2 a millimeter. Thank you for y’all’s time!!!!!
Should have zero movement side to side. Why would u think the busching would shrink. Wen it heats up it expands. Wen friends use solid bushing they put it on first to make sure its a perfect fit no movement. on shaft. Side to side.
The only one that i knonw of was a poly bushing shrinking. Wen check on shafted it fit perfect but wen installed it shrink. For the life of my friend could not get the shaft in wen trying to install. Bretblowblue had the extat same problem trying to install his shaft with the same bushing
