Front right signal doesn’t flash
Old Mar 12, 2023 | 10:30 PM
00iceman's Avatar
00iceman
Default Front right signal doesn’t flash
Hello! I have a 1998. The front right signal does not flash… unless either the parking light function is on, or headlights are on. I recently installed a hyper flash harness, along with LED DRL/signal bulbs and experience the same thing. Thoughts on where the problem may lie?
Old Mar 13, 2023 | 10:48 AM
grinder11's Avatar
grinder11
Probably a bad 4 way flasher unit. Could also be the multifunction switch. Turn on the turn signal, then try pushing the 4 way in and out several times. If it doesn't temporarily fix it at all, it could still be bad. If it is the original, 25 year old unit, you probably have your answer. Also, be sure the bulbs are both good!! If the brake lights both work, its not the bulbs...
