1999 A/C blower speed intermittent
1. Measure the voltage for that circuit at the FUSE. On top of each fuse are two test points (slots) Use a multimeter to measure each test point to chassis ground. You should see full battery (or very close to it) on BOTH test points.
2. With the circuit under load, insure that the voltage does not drop low. Electrical components DO NOT LIKE LOW VOLTAGE!
3. A true test to see if your circuit is fully able to supply the proper current and correct voltage under load is to load test the circuit with an incandescent lamp. If the lamp shines brightly, the circuit is passing proper current and adequate voltage.
4. Don't forget the circuit ground path. Our C5 are well known to have faulty ground connections. Always find and check the chassis ground point for that circuit. Make sure the connection is clean, tight and properly connected. A corroded ground is just as bad as a corroded power source connection. NO ground, NO Circuit!
Some Meter and Electrical facts/lessons learned. SCHOOL OF THE DAY: if you must! If you use a volt meter and read across a fuses test points in circuit with power applied, THEORETICALLY You should see zero volts, if the fuse is good.
If you see battery voltage, the fuse is BLOWN. If you see some voltage less than battery voltage, the connection inside the fuse (spade terminals, or fuse element ) is compromised and dropping voltage/current. You can use the same theory/practice with a ground terminal. Measure the wire terminal lug with one meter lead and a well known clean metal chassis ground with the other meter lead. If you see any voltage between those points, that ground connection is dropping voltage/current. The goal is no voltage drop.
There are a number of forum members that already know basic electrical theory and NO, I'm not trying to preach to the choir but a lot of the new members need this help.
Bill
Bill
Bill, as always thanks for your input !!…this diag was kicking my butt…as you can see in the scope capture which I thought I posted starting from the top the power (13 volts), HVAC data bus (0-7 volts), ground (0 volts), and blower signal (0-5 volts) were flawless…this capture was at 1 million samples per second so the slightest voltage drop would have been seen…no drop in power or ground but I will have to send a request to Alldata and Mitchell to correct the schematic.
