High-Speed Engine/Driveline Fluid Cooling
1) Can the engine oil stay below 230° F (110 ° C) at sustained high-speed with the current oil "warmer" that exists on the car? If not, what would be a sound method of cooling the engine oil other than resorting to an all-in-one coolant/engine oil-cooling radiator?
2) If I install a GM Performance transmission oil cooler, where do I mount the heat exchanger?
3) With the transmission oil cooler, and given that the differential has a small heat sink on the bottom, will the differential require a separate cooler for use at sustained high speeds?
4) Where would one recommend the inlet/outlet cooling hoses be placed on both the transmission and differential?
5) GM Performance wants nearly $2k for a single cooler kit. Is there a less-expensive source for these parts?
I've followed a meticulous break-in procedure that has involved changing all the driveline fluids twice in the first 5000 miles. I can also increase the viscosities to deal with the heat but would rather have better cooling as well.
I wonder what temperature data has been gathered by GM during their endurance runs in the Z06.
Thank you.
Brook Garrettson
garrettson@csd.com
Sam
microdynamic-engineering.com
They are suppose to have several oil cooler kits out that will fit your needs. I emailed them & their pricing is quite reasonable:
Diff cooler Kit = $695.00 includes pump, S.S. lines, cooler & all mounting brackets.
M12 / MN6 Tranny cooler kit = $695 includes pump, S.S. lines, cooler & all mount brackets.
LS1 & LS6 EOC = $495.00 includes oil cooler, new remote filter mount, adapter plate and S.S. lines with Goodridge connectors.
Corvette A4 tranny cooler kit = $199.00, includes cooler and SS lines with all mounting brackets.
They said their pricing and kit pictures will be up within the next 4 weeks. I can't believe the LS1 & LS6 engines do not have ANY kind of engine oil cooler from the factory!
