Passenger headlight opens half way sometimes
Old Mar 24, 2023 | 07:41 AM
ThomasR's Avatar
ThomasR
Default Passenger headlight opens half way sometimes
It's happened twice now in the last 2 days, intermittently. I turn the headlights on and the passenger side opens half way and stops. No noises are heard inside the car. If I turn the headlights off and on again it opens fully. Driver side operates normally. Is this a common problem with an easy fix? If not, where to start?
Old Mar 24, 2023 | 08:36 AM
DBS99MagRedCoupe's Avatar
DBS99MagRedCoupe
Possibly the plastic gear has stripped off a tooth or two?
Old Mar 24, 2023 | 03:41 PM
c5arlen's Avatar
c5arlen
Happens to me every now and then also.. but it always opens.. Best to not drive Corvette at night anyway since GM lighting sucks and it's a dangerous hazard to the car and ones eyeballs. 😏
Old Mar 25, 2023 | 05:35 PM
vette4fl's Avatar
vette4fl
Plan on a gear set rebuild kit. Simple job.
Old Mar 25, 2023 | 06:24 PM
eyekyu's Avatar
eyekyu
gear rebuild, replace it with brass gears. super easy!
Old Mar 26, 2023 | 04:51 AM
Moved to C5 Tech. BTW, it does sound like the headlight gear is the problem and needs to be replaced.
Old Mar 26, 2023 | 03:25 PM
rrwirsi's Avatar
rrwirsi
Before replacing anything, suggest making sure the connection from the motor with the control module connectors inside are tight. After I had my headlight motor replaced, I raising issues with it. The cure was assuring the connectors were tight. Another option the digging into the motor if you are not a DIY'er, just replace the motor,.
Old Mar 26, 2023 | 04:18 PM
vette4fl's Avatar
vette4fl
If you can get that far, replacing the gear is as easy as opening a can of beans.
To Passenger headlight opens half way sometimes
