TransGo question
Old Jan 14, 2003 | 07:06 PM
tgeers's Avatar
tgeers
Default TransGo question
Hi all,
Next week I'm having a sy3500 T/C and TransGo kit installed. I know there are 3 washers/spacers that can be used to tighten up the shifts. I also have read that most of you it seems are using 2 spacers.
My question is this: Can anyone describe the difference between just 1 and 2 spacers? My fear is 2 spacers will be too aggressive for dailey driving and 1 spacer won't justify the expense of installing the system.
Can anyone help me with these questions?
Vince, if you read this, I know you will have an answer.
Thanks everyone. :yesnod:
Old Jan 14, 2003 | 08:10 PM
Steve02C5's Avatar
Steve02C5
From: Renaissance Festival TAZ the Wolfdog (R.I.P.)
Default Re: TransGo question (tgeers)
I'm thinking mine must have been installed with one spacer because it doesn't shift as firm as my previous vehicles with the shift kit. Really it doesn't feel like there's a shift kit at all. :sad:
Old Jan 14, 2003 | 08:41 PM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
Default Re: TransGo question (Steve02C5)
Get 2, mine is a daily driver and I don't mind the little kick at all.
You will get used to it after a few minutes of driving.
Old Jan 14, 2003 | 08:53 PM
vstella's Avatar
vstella
First of all..You made the right decision to go with the Transgo shift kit..It will make ALL the difference. Those CF members without are under the misconception that programming alone will give them the crisp, lightning quick shifts like a Transgo.....NOT!!:nono:.. They will be envious after they get a demonstration in you NEW car....Trust me, their jaw will drop in awe:yesnod:!!
You are so right..2 spacers is the way go. It's a perfect combo for the daily driver...You will really enjoy the control after the install. I would suggest that you be sure that you ask the installer to drill the 1st,2nd and 3rd gear feedholes a little larger than suggested by Transgo. They will know what to do...The bottom line will be a transmission that YOU can control the shifts..up or downshift, hold the gears for a longer period and great throttle response..:D
The first time I drove the car home from the install I had a smile the whole drive home..I even took the long way!!..Once you feel comfortable with the transmission you will be launching with authority and and having fun driving your new car like a 6 speed..Enjoy! This is what the A4 should have felt like from GM.. :cheers:
If you have any specific questions feel free to e-mail me or my transmission tech Steve Atkins of East Coast Transmissions fhere in Fort Lauderdale, Florida. You can reach Steve at eastco@bellsouth.net or call him at 954-772-3000..he's the best!!
Old Jan 14, 2003 | 10:03 PM
Purerock105's Avatar
Purerock105
Default Re: TransGo question (vstella)
2 is the magic number for me as well. During the first 2-weeks or
so I would really notice the 1st to 2nd gear bump at low speeds,
but now I hardly notice. I certainly notice the WOT 1st to 2nd!!!!
:cheers:
Old Jan 14, 2003 | 10:11 PM
gojo's Avatar
gojo
If you can get a ride in a Transgo car it would be a good idea. I have 1 shim and did not like the 1-2 bump at slow speed. I programmed it to be softer at low Throttle position. At WOT it chirps between shifts. It's hard to know what we will like.
Old Jan 14, 2003 | 10:43 PM
tgeers's Avatar
tgeers
Two spacers it is :D
Thanks guys for the responses. I feel a lot more confident in what I'm doing now.
To TransGo question
