0306, key stuck in lock horizontally
Old Mar 25, 2023 | 10:30 PM
onespartn's Avatar
onespartn
Default 0306, key stuck in lock horizontally
Battery was dead so I charged it. Turns out I left the interior light on, but didn’t realize until after the fact. Also new battery and key fob. Car will lock and unlock with key fob and interior switches. Tried jiggling on numerous occasions, dry graphite, WD-40 etc. Key will not turn. Key is in good shape, no bends or cracks. Is there some sort of module that controls the locks, or some sort of relay?
Old Mar 26, 2023 | 04:40 AM
Moved to C5 Tech.
Old Mar 26, 2023 | 11:17 AM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Move the steering wheel?
Old Mar 26, 2023 | 11:34 AM
666lisa's Avatar
666lisa
The way i read it is its stuck in the door.
Old Mar 28, 2023 | 10:31 AM
grinder11's Avatar
grinder11
That's how I read it. When people need help, it's always best to try to describe in detail exactly what the problem is, and where it is.
Old Mar 28, 2023 | 11:30 AM
mmartinez's Avatar
mmartinez
To the OP, clarify where the key is stuck in the horizontal positiom is it the Ignition switch or door, any problems like this are usually in the internal mechanical workings of the key cylinder.
To 0306, key stuck in lock horizontally
