I installed headers Sunday and took it out for some testing afterwards. It was running very strong. I was in a short race with a Trans Am and really jumped on it the line. I bounced off my rev limiter twice. The car threw the code Monday; it is running rough and a bit warm. It also sounds off like running on 7. I used an EFI Live Auto tap but not sure how to interpret the screen to see if it will tell me which cylinder or cylinders are having problems. I replaced the plugs tonight and checked the wires, no problems. I also used a water spray bottle to verify that all cylinders were firing and all tubes were hot.
Do you all think it is a bent push rod?
How can I tell which one?
Should I just replace them all with aftermarket?
As always thanks for all the help my friends.
:confused:
Re: Code P0300 after headers, not plugs? (Steve'01)
I wouldn't think you bent a pushrod in an A4 if you got good programming. Did you get your shift points adjusted for the 3.90? If not you maybe correct.
Re: Code P0300 after headers, not plugs? (wallstAL)
These stock pushrods are VERY STRONG.Lpe specs stock on the TT 427 C5R .They like to keep a weak link in the chain to avoid over damage and limit liability.Even though I had no warrantty went with adj. Boost I have never come close to bending any component a truly strong motor.I LOVE my C5R.Dave S.
PS I will be swapping to chrome moly for reasons other than strength Dave S.
Re: Code P0300 after headers, not plugs? (Buckmaster)
I have gotten that code a few times after I put in all my mods in sig. So I don't know for sure which mod is causing it. The computer seems to be learning this out and I don't usually get it any more. It just went away.
Checked all of the pushrods tonight, none were bent. Then I started compression tests. I was happy to see 160, 159, 160 then 60, #7. I was too bummed to keep checking the other side. I figure that I will have to pull it this weekend anyways. I put some oil down the plug hole and rechecked and still 60lbs. If I remember correctly that means that the piston and rings are OK. I plan on checking the head gasket and valves Saturday. Trying to keep a positive attitude. Hard to tell the wife I brook my car. :sad: :sad: :sad:
Re: Code P0300 after headers, not plugs? (tabbruzz)
Did the leak down test tonight. At first I thought the air was going into the intake, but no such luck. It was coming out of the dipstick and around the holes in the heads where the push rods go through. The piston must not be tore up because I still have some compression and she still runs fair. At first I was very bummed almost sick, but need to look at the way the rest of you have, good reason to beef it up. Oh well, tomorrow I plan my new bottom end. Thanks for the words of encouragement. Too bad I sold that extra car. :sad:
