Hyper flash bypass installed now no hazard or signals
Old Mar 31, 2023 | 03:37 PM
1stvetteRED's Avatar
1stvetteRED
2nd Gear
Default Hyper flash bypass installed now no hazard or signals
New to the forum and my first vette red C5 hatchback. Left turn signal is hyper flashing. Hazard, brake lights, right turn signals all work. Left front signal hyper flashes and both rear bulbs dead. Replaced front bulb and both rear, not LED's. Bought and installed the bypass harness,, now the hazard lights and turn signals do nothing. Thought maybe a bad harness so bought another and it does the same thing, nothing. Any ideas?
Old Mar 31, 2023 | 04:16 PM
link9a's Avatar
link9a
Originally Posted by 1stvetteRED
New to the forum and my first vette red C5 hatchback. Left turn signal is hyper flashing. Hazard, brake lights, right turn signals all work. Left front signal hyper flashes and both rear bulbs dead. Replaced front bulb and both rear, not LED's. Bought and installed the bypass harness and installed,, now the hazard lights and turn signals do nothing. Thought maybe a bad harness so bought another and it does the same thing, nothing. Any ideas?
if you don't have led bulbs that means bad hazard switch need to replace ...
Old Mar 31, 2023 | 04:20 PM
1stvetteRED
2nd Gear
OK, got one on order and planned to replace. For some reason I thought this bypass harness was a cure for all signal hyper flash problems if the bulbs were good.
Thanks for the quick reply
Old Mar 31, 2023 | 04:23 PM
link9a's Avatar
link9a
No problem ....Sometimes the ground need to cleaned . Hyper flash relay they use it if you have led bulbs ....
To Hyper flash bypass installed now no hazard or signals
