12 disk CD player
Old Apr 2, 2023 | 05:25 PM
2010Pony's Avatar
2010Pony
Default 12 disk CD player
Went for my 1st ride of the year today and it was wonderful! The radio was not showing a CD disk symbol and would not play. Removed all disks and reinstalled them into player several times and they are in correctly you can hear it working in the player but nothing on the radio. Cassette player and radio works fine and the CD did last year before i put it away. Going to unplug it tomorrow and see if that does anything, any suggestions would be great. 2000 M6. And like before got the gas gauge drops to zero after 50 miles, reset code and came back up. Thanks
Old Apr 2, 2023 | 05:36 PM
2010Pony's Avatar
2010Pony
Yes they are but you have to love them 🍺
Old Apr 2, 2023 | 06:50 PM
grinder11's Avatar
grinder11
Originally Posted by Hawks10
You've got to love the C5. It has electrical issues that would give a Thomas Edison/Nikola Tesla tag team fits!! AFAIK, it's the only car that GM made that can run its own DTC scan, and code delete. Probably the only one that can really use it, too!!
Old Apr 3, 2023 | 03:02 PM
2010Pony's Avatar
2010Pony
Found my problem, there was a CD stuck inside must been from last year. Working great now
Old Apr 3, 2023 | 03:22 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
I think the 12 CD changer is a cool option. Does anyone know if there is a pig tail that is already run to the rear of the car that can just be a plug in?
Old Apr 3, 2023 | 03:36 PM
2010Pony's Avatar
2010Pony
Not sure mine was a option and already in there. Also got a cassette adapter at Walmart today and a Apple connector so I now can play my Sirius/ play list from my iPhone and a total cost of about $18.
Old Apr 6, 2023 | 01:39 PM
Justin Raney's Avatar
Justin Raney
Yes are other cars equipped with the 12 disc changer plug?
Old Apr 6, 2023 | 03:16 PM
grinder11's Avatar
grinder11
I'm pretty sure some Cadillacs had the 12 disc changer, and I think it was an Fbody option, too.
Old Apr 6, 2023 | 03:17 PM
Justin Raney
What years did they put the 12 disc cd changers? May i ask if a 99 coupe has the same wiring or same as 00 convertible cd player or are the body style harness different?
Old Apr 6, 2023 | 03:49 PM
tabbruzz's Avatar
tabbruzz
Pull the fuse and plug back in. It will not be blown, but it resets the radio\cd changer. The fuse panel is under the passenger foot well for the radio....
Old Apr 6, 2023 | 04:24 PM
MitchSpence's Avatar
MitchSpence
I wish we still had an option of a CD player on the C8. Or have an option of nothing and let you put your own unit in.
Old Apr 6, 2023 | 07:07 PM
PHILLY JOE's Avatar
PHILLY JOE
PHILLY JOE
Not many. They are available on line . The conector is up front passenger side after your plastic door sill is removed up front on RIGHT SIDE can,t miss it.
To 12 disk CD player
