C5 wheel speed sensor
Old Apr 2, 2023 | 09:34 PM
wtlee3's Avatar
wtlee3
1st Gear
Default C5 wheel speed sensor
Good evening, I just purchased a 2004 C5 with 16,000 miles. I’m fixing a few things like window regulator , reverse switch and now working on a speed wheel sensor issue. This forum has been super helpful..so , thank you. Now to my issues; my ABS /traction control light is on. I could see the sensor output jump at 30 mph and only 30 mph. I replaced the dongle but it didn’t fix. So I replaced the hub yesterday with a skf and now the ABS /traction control light comes on as soon as I start moving. Any thoughts?
Old Apr 2, 2023 | 09:57 PM
jcgunn's Avatar
jcgunn
Use the DIC to pull the codes and let the car tell you what is wrong.
Old Apr 4, 2023 | 11:23 AM
Missileboy's Avatar
Missileboy
what he said and make sure your battery is good. I am not saying a bad or weak battery is the problem, a lot of the gremlins in GM cars of this era can be exacerbated by a less than 100% healthy battery, so it sucks to trouble shoot not starting from a good place!
Old Apr 4, 2023 | 12:22 PM
johnson-rod's Avatar
johnson-rod
Check the plug in the wire to the hub. The pins get corroded and/or bent and no longer make good contact. Then they don't make any contact at all. This sounds like your problem. Easy to take apart and clean.
To C5 wheel speed sensor
