Changing oil pressure sensor....
Old Apr 10, 2023 | 08:37 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default Changing oil pressure sensor....
Sup all, so question and seeing the hundreds of posts iam very surprised this hasn't been mentioned before. I have a 2002. Bad oil pressure sensor. Not uncommon for our C5s. BUT when changing out the sensor is there a filter screen down the sensor hole? Iam told by my brother he believes there is and therefore that will need to also be purchased and changed out at the same time. I guess the screen can get clogged and therefore cause the sensor to go bad or produce bad readings? I have looked all over the web and youtube, Iam not finding any mention about the filter screen and people changing it. Being you can't see down there and it isn't shipped with a new sensor, perhaps people all these years are unaware that it is down in that hole?
Old Apr 10, 2023 | 10:00 PM
vette4fl's Avatar
vette4fl
Old Apr 10, 2023 | 10:44 PM
Johnny Hardcore's Avatar
Johnny Hardcore
It hasn't been mentioned because there isn't a filter screen in the LS1 or LS6. I believe the filters are only in vehicles with AFM manufactured after 2005. And I don't think any if them are vettes.
Old Apr 11, 2023 | 09:36 AM
Johnny Hardcore
Apparently all C7's with the exception of the 2019 ZR1 come with AFM. Or So I've just read. So I was incorrect above as the later C7 vettes came with it. None the less, the C5 doesn't have AFM nor the OPS filter..
Old Apr 15, 2023 | 08:30 AM
Missileboy's Avatar
Missileboy
I can see why people think it needs the screen, alot of the replacement sensors you buy (like Dorman) come with the screen since these items are compatible across alot of platforms.
To Changing oil pressure sensor....
