Speedometer pegged
Old Apr 14, 2023 | 08:20 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
Default Speedometer pegged
I saw a fifteen yr old thread that didn’t resolve the problem. Happened after a dead battery and subsequent charge. Tried pulling and placing the battery cables. No startup sweep. Nothing. All other gauges working fine. Please tell me it’s a simple fix. Thx
Old Apr 15, 2023 | 05:13 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
Sounds like the cluster is bad. If all of the gauges sweep except for the speedometer it's probably an internal custer failure since the gauge should always sweep when the key is turned on. Changing cluster is not as bad as it seems.
Old Apr 15, 2023 | 05:28 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
As above you may need a new cluster if everything sweeps but the speedo. However, you mentioned a dead battery and a charge. I'd first get a new (new) battery and put that in. Our C5s are very wonky with electrical situations and a weak battery tends to bring out the worse. What does your DIC say for battery condition?
Old Apr 16, 2023 | 08:28 AM
jbondfl's Avatar
jbondfl
Battery is almost new. It just sat for a month and trickle died because I didn’t use the trickle charger 😒.
Old Apr 18, 2023 | 09:36 PM
jbondfl's Avatar
jbondfl
Bump
To Speedometer pegged
