Running light /turn signal
Old Apr 20, 2023 | 02:26 PM
jamime's Avatar
jamime
Default Running light /turn signal
I’ve had problems with my front running light /turn signal bulb burning out. So I replaced the entire socket. It lasted 30 minutes of driving and burned out again. Frustrating, any ideas? Thanks
Old Apr 21, 2023 | 09:13 AM
Rich Silvestris's Avatar
Rich Silvestris
St. Jude Donor '05
You may have water getting in there. The heat from the lamp can cause cracks to form in the top of the housing.
I had a similar problem, but not as severe as what you describe. New housings and LED's fixed it (along with a new socket).
Old Apr 21, 2023 | 10:12 AM
JBB's Avatar
JBB
Yes, the top melts just over the bulb. Then the bulb blows going through the car wash or rain. I've "fixed" a couple using a piece of aluminum tape to seal the leak.
To Running light /turn signal
