REVERSE-SPLIT CAM WITH STOCK LS1 HEADS?
Old Jan 16, 2003 | 12:30 AM
MEGA ONE's Avatar
MEGA ONE
Default REVERSE-SPLIT CAM WITH STOCK LS1 HEADS?
I AM INTERESTED IN A THUNDER RACING REVERSE-SPLIT CAM. I WANT NASTY, BECAUSE I IN THE FUTURE AM GOING WITH STAGE2 LS6 HEADS WITH DUAL SPRINGS. JUST WANT TO GET BY FOR NOW AND NOT HAVE TO SWAP CAMS LATER. ALSO SHOULD I DYNO AFTER INSTALLING NEW CAM. MEGA1 :lol:
Old Jan 16, 2003 | 10:14 AM
Chris@SD's Avatar
Chris@SD
Default Re: REVERSE-SPLIT CAM WITH STOCK LS1 HEADS? (MEGA ONE)
The Thunder cams are pretty nice camshafts. We have been using quite a few of them lately and all have fired off pretty well. We will be installing a 230/224 cam in a 99 C5 Tuesday with stock heads. We can post some results if you are interested.
We did one in an F-body and with custom dyno tuning, we ended up with 406/391. This with stock heads!
Give me a call if you need any help picking the correct camshaft for what you are looking for oor anything else you may need.
Old Jan 16, 2003 | 10:24 AM
MEGA ONE's Avatar
MEGA ONE
Default Re: REVERSE-SPLIT CAM WITH STOCK LS1 HEADS? (Chris@SpeedDemon)
HEY CHRIS, AWESOME STATS, ARE YOU INSTALLING THE REV-SPLIT CAM, YES I WOULD LOVE RESULTS. ARE YOU GOING TO DYNO TUNE AFTER INSTALLATION. I AM IN KILLEEN , TEXAS ABOUT 4 HOURS AWAY FROM YOU I GUESS. THANKS MEGA1
Old Jan 16, 2003 | 10:55 AM
Closer_2001's Avatar
Closer_2001
Mega1
Heard lots of great things about the Rev split. Interest started to peak last spring with the G5 and TR Cams.
I am also interested to see the results with stock heads.
BTW: Writing IN CAPS MEAN YOUR ARE MAD OR YELLING.
You may want to refrain.
Good Luck, Happy Vetting :cheers:
Old Jan 16, 2003 | 11:24 AM
RWE 427's Avatar
RWE 427
Veteran: Marine Corps
Chris, Please post the dyno #'s when you get them. :cheers:
Old Jan 16, 2003 | 11:25 AM
Face's Avatar
Face
Default Re: REVERSE-SPLIT CAM WITH STOCK LS1 HEADS? (Closer_2001)
:yesnod: :yesnod: :yesnod:
Old Jan 16, 2003 | 11:38 AM
Shinobi'sZ's Avatar
Shinobi'sZ
Default Re: REVERSE-SPLIT CAM WITH STOCK LS1 HEADS? (Face)
The cap stuff gets annoying..but maybe he does not know yet.
Back to your question. I would recommend changing the valve springs with that particular cam choice. I changed my springs out. My cam is a 224/224 .581/.581 114 lsa. You should run a dual spring setup..then you can use the same springs on your LS6 heads (when you do them) and save some money. Other than that my Heads are stock LS6 heads.
[Modified by Shinobi'sZ, 10:39 AM 1/16/2003]
Old Jan 16, 2003 | 02:27 PM
Chris@SD's Avatar
Chris@SD
Hey Mega,
Yup! The cam we are installing on Tuesday is a reverse split cam (230/224) and is going on a Corvette. It will be dyno tuned hopefully the same day and results can be posted. Now just need to go get a scanner, now that I have 20-30 dyno graphs to post.... :)
Come by the shop if you are ever in Houston and we will give you the grand tour. :yesnod:
Old Jan 16, 2003 | 02:39 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Hey Mega,
Post away :D I have plenty of questions. So many choices...... :yesnod:
To REVERSE-SPLIT CAM WITH STOCK LS1 HEADS?
