Replaced transmission fluid
Old Apr 27, 2023 | 04:18 PM
2010Pony's Avatar
2010Pony
Default Replaced transmission fluid
2000 6 speed base. Drained manual transmission fluid for the first time today, used bottom drain. Let all run out that would and was only able to refill with just under 4 quarts before it started coming out the top refill hole. Thought this was supposed to take 5 quarts. Thanks
Old Apr 27, 2023 | 04:53 PM
feeder82's Avatar
feeder82
on a rebuild it's only 4qts, drain and fill 3 or so
Old Apr 27, 2023 | 05:18 PM
2010Pony's Avatar
2010Pony
Thanks, I don’t know where I came up with 5 after more research I see that, might have been NAPA that told me.
To Replaced transmission fluid
