B0361 code left actuator feedback short to ground
Old Apr 30, 2023 | 11:28 AM
Rocketship91's Avatar
Rocketship91
Default B0361 code left actuator feedback short to ground
Hey all thanks in advance as always! I have the code in the title B0361. Can someone point me in the right direction on where to find the grounding spot for the hvac system? I think this might also be causing another code of B0441- left heater ventilation ac actuator out of range. Let me know if someone has had this issue and if cleaning the ground connection actually fixed it. Thanks again!
Old May 2, 2023 | 07:29 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
Have the same codes. The drivers side ac outlet is warmer than the passanger side and getting worse. Will be changing out the actuator and I'll let you know if it fixes the issue.
