corvettTom
Old May 2, 2023 | 12:34 PM
corvettTom's Avatar
corvettTom
3rd Gear
Default corvettTom
I have a 2000 C5. Yesterday I turned started the car and all the lights started flashing real fast. I sure it has something to do with the security or anti theft on the car. Has anyone had this problem and how did they fix it.
Old May 2, 2023 | 01:41 PM
c5arlen's Avatar
c5arlen
No I have not had that problem Tom... but someone here gunna help ya... Perhaps refraze the question ?
Old May 2, 2023 | 02:24 PM
corvettTom's Avatar
corvettTom
3rd Gear
When I start the car, all the exterior lights start flashing really fast. Has anyone had this problem and how did they fix the problem?
Old May 2, 2023 | 02:34 PM
killain's Avatar
killain
Oldtimer
I'd first check the Battery to make sure it's fully charged up. Then I would pull any trouble codes to see what the ECM has to say. Then I'd have a local autozone check the alternator, between those I'm sure some more talented techs here would be helpful for you.
Old May 2, 2023 | 03:37 PM
corvettTom's Avatar
corvettTom
3rd Gear
OK I will start there. Thank you
Old May 3, 2023 | 12:00 AM
jim993's Avatar
jim993
Battery charge: 12.6 volts MINIMUM
You have to check battery voltage across the battery terminals. If you don't have a multimeter, get one, they are cheap.
Make sure the battery terminal connections are clean ant tight.
Old May 3, 2023 | 01:46 AM
Moved to C5 Tech.
Old May 3, 2023 | 09:40 AM
grinder11's Avatar
grinder11
As for tight battery terminals, make sure you actually are tightening the cables to the battery Because on some known occasions, the cable bolt bottoms out just as it's starting to clamp the cable to the battery. A quick way to check this is after tightening, grab the cable and try twisting it around the bolt. If the cable moves at all, the bolt needs shortening.
Old May 3, 2023 | 10:40 AM
Dads2kconvertible's Avatar
Dads2kconvertible
If the Universal Theft Deterrent system is active it should also sound the horn and also disable fuel delivery and cranking.
This screenshot is from my 2000 manual, I can post other pages if you want them.
To corvettTom
