Negative Battery Cable Connection to block
Old May 3, 2023 | 09:43 PM
jrp1588's Avatar
jrp1588
Default Negative Battery Cable Connection to block
This is embarrassing, but I started a crank sensor job over the weekend, took out the headers, moved a bunch of wiring out of the way, etc. Came back to button it up tonight, and I don't have any memory of doing it, but I guess I unbolted the main negative battery cable from the frame/block, and I can't for the life of me figure out where it's supposed to go. I don't even have an extra bolt laying around that I'd need to secure it. Apparently it's so obvious, no one on the internet has ever bothered to draw a diagram or take a picture. It looks like it wants to go to the starter, but I'm pretty sure the starter gets its negative connection through the block. Pictures seem to confirm this.
Old May 3, 2023 | 09:50 PM
666lisa's Avatar
666lisa
https://www.google.com/search?q=C5+w...APHiimIFp3QmCM
Old May 3, 2023 | 10:08 PM
jrp1588's Avatar
jrp1588
This is on the block itself? Not the head or the frame? It looks like it's straight up from the solenoid. I felt all over the are, and didn't find a mounting point. Mine is a 2001, and the previous owner put in a 6lr LQ9 truck block if that changes things. I can reach a bolt on the head with it that's already being used for a ground, but I know that's not where it came from since it's still bolted up. I could swear I never touched this thing, but I've been driving this car for 5 years. It must have been connected.
Old May 4, 2023 | 12:20 AM
Moved to C5 Tech.
Old May 4, 2023 | 05:38 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
It is above the starter.
Old May 4, 2023 | 08:59 AM
jrp1588's Avatar
jrp1588
Thanks. I don't think my block has this I just looked it over, and stuck my phone camera down to record the area for good measure. Are truck engines different? I know that small grounding wire that is with the big one is on the head on mine. I'm assuming I can just put the big one up there with it?
Old May 4, 2023 | 09:12 AM
C5 Diag's Avatar
C5 Diag
I don’t know about truck engines but the big cable (battery negative cable) and the small wire (PCM ground) go to the block…what was your initial problem..a crank no start…is this why you changed the crank sensor ??
Old May 4, 2023 | 09:27 AM
jrp1588's Avatar
jrp1588
I had RPMs occasionally drop to zero and the car die while driving, then it would come back. It did the same thing years ago when the headers where melting the wiring to the sensor. I just felt around some more, and I did feel something tucked almost between the starter solenoid and the block that could be a mounting point. Didn't feel as angular or as large as what's in the picture though, and I don't think I can get a wrench on it without removing the starter again. Should I be able to see this mounting point from the top of the engine?
Old May 4, 2023 | 09:32 AM
C5 Diag's Avatar
C5 Diag
With the RPM dropping like that and car shutting down certainly sounds like a crank sensor…so did you actually change your crank sensor ??….trying to read your post and figure out what’s been done…so now the car doesn’t start ??…we just need all the info.
Old May 4, 2023 | 03:25 PM
jrp1588's Avatar
jrp1588
I changed the sensor, now I'm reassembling. Thing is, this project was done over several days, and I guess I've forgotten I disconnected this cable, and I'm having trouble finding where it goes on the block.
Old May 4, 2023 | 03:27 PM
C5 Diag's Avatar
C5 Diag
If it’s a truck block you’ll have to research that.
Old May 4, 2023 | 03:36 PM
jrp1588's Avatar
jrp1588
I'm unconvinced I disconnected it at all. There was some real hillbilly stuff done with the wiring on this car. I wouldn't be surprised if it was just jammed in contact with the block somewhere, and I dislodged it when I moved the wires to get the headers out. I always take all my bolts from a project and keep them organized for reassembly, and I don't have any missing. Think I'd be OK just bolting it to the head with the other ground?
Old May 4, 2023 | 09:24 PM
jrp1588's Avatar
jrp1588
Well it's back together and running, I put the cable to the head with the other ground. It's running a bit rough, and with some mean backfires. I was hoping I'd be one of the people who could get away without doing a crank sensor relearn, but guess I'll need to procure a Tech II or clone.
Old May 8, 2023 | 09:26 PM
jrp1588's Avatar
jrp1588
Got a fancy scanner that can do crank relearning, ran it twice, and the car is still running like absolute crap. I suspect something is off with the wiring. Either it hates where I put the main ground on the head, or the solder joint on the new crank sensor harness that I thought was iffy but passable was not, in fact, passable.
Old May 9, 2023 | 09:05 PM
jrp1588's Avatar
jrp1588
I was able to find these photos of a 5.3 truck block. It look like there IS a different situation going on above the starter where the LS1 would normally have a main ground connection. I couldn't see that round projection, but that's definitely what it felt like when I was groping around. I guess I'll tear back into it for a third time this weekend to investigate. I can't reach or do anything with the dang headers in the way.
Old May 10, 2023 | 02:22 PM
grinder11's Avatar
grinder11
I hear ya about headers being in the way! I also know these LS PCMs dont like any grounds but the very best!! The cable is mounted on the block for a reason. I see a couple bosses with holes, just in front of the starter, one higher vertically than the other. Are they tapped/threaded? If this is a cast iron block, and they're not threaded, you'll need no cutting oil when tapping the cast iron-The graphite content in the iron acts as a great lube. Best of luck.....
Old May 11, 2023 | 08:50 AM
jrp1588's Avatar
jrp1588
I believe those are threaded, yes. Not entirely sure the cable will reach them, and I think they were partially obstructed by a big bracket of some sort, It's been a few days since I was in there, maybe part of a mount for the AC compressor. I'll find a spot for it, I just want to know where the damn thing was connected BEFORE. The smaller ground was definitely on the head, so that's wrong. The correct position for this one doesn't exist, and I don't recall touching it. I swear this damned car is gas lighting me. lol
To Negative Battery Cable Connection to block
Old May 13, 2023 | 10:56 AM
grinder11's Avatar
grinder11
Bottom line is the negative cable originally bolted to the block. Truck blocks aren't so much different than LS1/LS6 blocks. The cable should be mounted where GM mounted it; on the block.. clean off any surface rust, get a short bolt, a proper sized eyelet, and bolt it to the block.....
Old May 13, 2023 | 12:15 PM
jrp1588's Avatar
jrp1588
I will, just gotta find the a spot for it. The stock mounting spot DOES NOT exist on my block. If you look at the pictures I posted, there clearly is a difference here.
Old May 14, 2023 | 02:09 PM
grinder11's Avatar
grinder11
But it looks like the block does have threaded holes, perhaps just in a bit different location. Maybe you could check out a negative cable at the salvage yard for a 6.0 block? Maybe it's longer. Or-Get a piece of flat stock aluminum, drill a clearance hole on the end that bolts to the block, and drill and tap the other end for mounting the ground cable. You're basically making an extension from the block to bolt the ground cable to. If using aluminum, a 3/16"-1/4" thick, 3/4"-1" wide, whatever length you need to accomodate the too short cable. Use a bit of dielectric grease on the block end to protect from dissimilar metal/galvanic reaction damaging the block. Or maybe a longer ground cable. Best of luck......
