C5 Parasitic Draw
Old May 11, 2023 | 04:53 PM
GENOVANELI's Avatar
GENOVANELI
Default C5 Parasitic Draw
I need to get my c5 to go to sleep with the doors and hood open to test for a draw on the battery. I have saw on videos where you use a screw driver on the door latch to make the computer think the door is shut then you simply pull the door handle to go back to normal state. My question is can I use this same process on my hood latches to make the computer think the hood is closed and will pulling the hood latch in the car, return the hood latches back to normal state?
Gene
Old May 11, 2023 | 07:43 PM
mmartinez's Avatar
mmartinez
Not understanding why you need to keep the doors and hood open to measure for a parasitic draw unless you want to measure millvolts across the fuses. I would recommend connecting the DVM in series set to 10 amp setting with the negative battery terminal and negative cable, you should have about 25ma after 20 minutes.
Old May 12, 2023 | 01:33 PM
mmartinez's Avatar
mmartinez
Hello again, will explain how to locate a parasitic drain on a c5. Step 1: connect dvm configured as an ammeter in series with the negative battery terminal and negative battery cable. Step 2: lift the positive battery cable from the engine bay fuse box, insulate so it doesn't touch ground. This leaves the positive battery cable that connects to the starter and alternator. If you have any current drain then the alternator is causing a current drain. Step 3; After elimaniting the alternator as the source of current drain, lift the positive cable that powers the interior fuse box and re-measure the current drain, once you have determined which fuse box has the excessive current drain you can then defeat the doors or hood switch and reconnect negative battery cable and take millvolt readings across the fuses.
Old May 12, 2023 | 01:45 PM
averagejoesautos's Avatar
averagejoesautos
Or if your lazy...and have a few bucks to spend...buy an AMP HOUND. It simplifies the step diag procedure mmartinez described [which is the correct way of chasing an amp draw]. However, for someone who is not familiar with the procedure will probably lead to an inconclusive result.
Check the power seats...8/10 times whenever I've chased a parasitic draw...the power seats typically come up in the top 3 suspects I look at.
Good Luck.
Old May 12, 2023 | 01:55 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
After you connect the ammeter at the battery the car will go to sleep in about 15 minutes. Even if the doors and hood are open the lights should go off and you can measure the sleep current.
Old May 12, 2023 | 02:10 PM
ThomasR's Avatar
ThomasR
You don't have to close the hood latches. Watch the under hood light and when it goes out the car is going to sleep.
Old May 23, 2023 | 05:06 PM
GENOVANELI's Avatar
GENOVANELI
It was the control module on the driver side seat.
Old May 23, 2023 | 08:48 PM
johnson-rod's Avatar
johnson-rod
It usually is...
Old May 23, 2023 | 10:49 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If the seat control switch unit fails to return to the center neutral position on the switch, it can stick in one position and cause the motor/motors for the seat to continue to drive UNTIL it trips the resettable relay fuse in the passengers foot well fuse box. It will do that until the battery dies! Make sure the switch functions properly returning to the center position. The switch for the lumbar can do the same thing.
Old May 24, 2023 | 07:05 AM
averagejoesautos
Good Luck.
I guess its 9/10 now Glad you found it. Time for some Amazon racing slider seats lol. You could get some refurbed used seats, but I looked into the cost and 600 to 1200 to replace a seat is kind of steep for seats that sucked when brand new lol Both Amazon seats for me were $490 with the slider brackets. Sure its not original...and a little bit of drilling to the bracket is required but beats parasitic draws that kill your battery in 3 days
To C5 Parasitic Draw
