Stock Bottom End question....
Old Jan 16, 2003 | 08:07 PM
SvenOdin's Avatar
SvenOdin
Default Stock Bottom End question....
Forgive my ignorance, but what specifically is the "stock bottom end"? I see this discussed on various boards in relation to drag racing, but never have I seen what specifically makes up the bottom end.
Is it the transmission, output shaft, differential???
I also see reference that stock is a 10 bolt, and recommendation is a 12 bolt.
Can someone please explain this to me so I can have a clue??!!
Thanks!
:cheers:
Old Jan 16, 2003 | 08:14 PM
Patches's Avatar
Patches
Default Re: Stock Bottom End question.... (SvenOdin)
Stock bottom end is the factory engine block and rotating assembly including the crank, piston rods and pistons, etc. The top end includes heads, valves, intake, etc.
A 12-bolt rear end is a heavy-duty diff. In referring to LS1's, those typically are used on f-bodies.
Here's a pic of his C5R short block a forum member sent me. (Thanks, Rich)
[Modified by Patches, 8:28 PM 1/16/2003]
Old Jan 16, 2003 | 08:41 PM
Gary2KC5's Avatar
Gary2KC5
Default Re: Stock Bottom End question.... (Patches)
I "beefed" of the bottom end when I had my engine rebuilt.
It just means you use much stronger parts in the short block or "bottom end"
unually that means using forged parts like forged pistons, and stronger bolts like ARP rods bolts, a stronger timing chain, etc. etc.
Old Jan 17, 2003 | 09:30 PM
CapeCodCoupe's Avatar
CapeCodCoupe
Default Re: Stock Bottom End question.... (Gary2KC5)
I give up...what is a short vs. long block LS1 ? :confused:
Old Jan 17, 2003 | 09:42 PM
SvenOdin's Avatar
SvenOdin
ok, makes some sense now. Thanks for the info!
:cheers:
Old Jan 17, 2003 | 09:51 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Stock Bottom End question.... (CapeCodCoupe)
Long block is short block + heads. It usually is a complete engine. Short block is just the internals + block (no heads) * or cam sometimes
Old Jan 17, 2003 | 10:10 PM
Steve02C5's Avatar
Steve02C5
From: Renaissance Festival TAZ the Wolfdog (R.I.P.)
Sven, ask Chris at SpeedDemon, isn't your car there?
To Stock Bottom End question....
