3:73 rear end
There are several ways that you can get 3.73 gears. You can buy a new complete rear from a Forum vendor this will cost you about $1695.00 outright (no Core needed). You can check the C5 Parts For Sale Section you can sometimes buy one used for $1000.00-$1100 for a unit that is in good shape. You can buy just the ring and pinion for $350.00-$400.00 and have it installed in your carrier, the labor should be about $200.00-$300.00 plus parts if the rear is already out of the car. Last but not least you can buy a rebuilt complete rear from a forum vendor for about $1195.00 plus a core.
98 A4
Donaldson Blackwing
Cartek Stage 2 Heads
Cartek M Cam
LS6 Intake
TPIS Headers
Underdrive Pulley
Comp Push Rods
Rev 1116 Valve Springs
172 t.stat
Borla Exhaust
ST3500
3.73 Gears
B&M Trans Cooler
[Modified by Mitch C, 3:46 AM 1/17/2003]
