Which one???
Old Jan 17, 2003 | 09:36 AM
c5 devil's Avatar
c5 devil
Default Which one???
Okay guys i do not know what to do.....I only can do one of those two things right now:
1) 3.42 gears...and a 2800 TC
or
2) T.P.I.S headers, corsa catback exhaust, U.D pulley.
I have a c5 99 vert. stock automatic. with 61k miles..... :reddevil
Old Jan 17, 2003 | 04:57 PM
Mitch C's Avatar
Mitch C
Default Re: Which one??? (c5 devil)
Performance wise the 3.42s and the 2800 stall T/C will give you a MUCH BIGGER performance boost especially if you have 2.73 gears. If you have not already bought your T/C you might want to consider a converter with a bit more stall between 3200 to 3500 stall. You did not mention which 2800 stall converter you were considering. If you are thinking about the Vigilante 2800 that is an excellent choice since it really stalls at 3200 RPM.
I would not install an underdrive pulley if I was not also going to install a new cam at the same time. Installing an underdrive pulley by itself involves too much work for too little gain.
98 A4
Donaldson Blackwing
Cartek Stage 2 Heads
Cartek M Cam
Underdrive Pulley
TPIS Headers
LS6 Intake
Comp Push Rods
Rev 1116 Valve Springs
172 t.stat
Borla Exhaust
ST3500
3.73 Gears
B&M Trans Cooler
LS1 Edit Tuning
[Modified by Mitch C, 9:36 PM 1/17/2003]
Old Jan 17, 2003 | 09:43 PM
Cartier1's Avatar
Cartier1
Go for the 3.42 gears and the TC!!!!!!!!!!!!!!!! :smash:
Old Jan 17, 2003 | 09:44 PM
MY Vette's Avatar
MY Vette
Go Gears! :yesnod:
Old Jan 17, 2003 | 09:45 PM
SvenOdin's Avatar
SvenOdin
Gears and TC
:cheers:
Old Jan 17, 2003 | 09:49 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Which one??? (SvenOdin)
gears and t/c :iagree:
To Which one???
