My 97 is driving me crazy. A few weeks ago my turn signal stopped working so I tried the hazard switch trick so that didn’t work.
ordered a new switch and still didn’t work.
Well on my way home, my buddy told me my right side brake lights don’t work!
I thought it was maybe the turn signal switch but now the brake light threw me for a loop.
The brake issue only happens intermittently while the turn signal is a constant issue.
I checked the ground pack by the tail light and they weren’t corroded but I clean them.
Hazards still work
Have you taken the lights out and inspected the bulbs and sockets? When I swapped mine out to LED's, the sockets had some corrosion in them, so I cleaned them out good and sprayed some dielectric in there. could be that simple-
