Ticking after modifications LS1
Old May 23, 2023 | 10:56 AM
Maximus881's Avatar
Maximus881
Default Ticking after modifications LS1
Hi. I bought a Corvette C5 which has modifications:
- Street Sweeper HT Cam 228/232 .600/.612 111 LSA
-Lunati Dual Valve Spring Kit
-JP Double Roller Timing Chain
-Manley Chromoly Pushrods
-Comp Cams LS Trunion Upgrade Kit
-Powerbond Underdrive Crank Pulley
-Long tube headers OBX with hiflow cat
-Corsa Exhaust
-SLP Blackwing Cold Air
-Precision Industries 3400 Stall Converter
-Tea Stage 2 ported 243 heads
-Fast LSX 92 intake ported and ported LS2 TB
-42lb injectors
-AI 226 ported 243 heads - CR 11,1
I found a thread on this forum of the previous owner so I know what modifications it has. However, I am concerned about the ticking sound from the engine. I can hear the exhaust manifolds buzzing, I can also hear the work of the changed injectors, but my mechanic believes that the sound is made by lifters. He thinks this is normal after changing to a sport camshaft and double valve springs. The car has already done 12,000 miles since the modification. I have done 6,000 miles with this car.
I recorded a video. Please take a look.
https://youtu.be/HaWl3cMWb7M
Old May 23, 2023 | 01:06 PM
feeder82's Avatar
feeder82
Sounds normal for a cammed motor with headers. The sewing machine sounds are typical
Old May 23, 2023 | 01:25 PM
Davcruz's Avatar
Davcruz
Sounds just like mine, which is similarly modified. I know, they are not as quiet as you think, it bugs me too.
Old May 23, 2023 | 01:33 PM
Maximus881's Avatar
Maximus881
I don't know how long the push rods are. The previous owner was making modifications to the new era performance in NYC in 2015
Old May 23, 2023 | 02:19 PM
averagejoesautos's Avatar
averagejoesautos
Welp...measure the pushrods then
I never understand those who buy modified rides and expect them to sound like Nissan Versa's lol While not a super aggressive cam, the stock lift on an LS1 cam was .479/.467 and your cam is now .600/.611 lift. If your question is whether or not the work was done right or if the rockers are loose and out of adjustment...its very simple to check and verify. But as others have said...sounds about normal. The one thing MODIFIED owners need to understand is...you will have to be TWICE as vigilant monitoring noises and gauges as the stock'ers will be. That's part of being modified...always has been...always will be.
You put 6,000 miles on the car...if it aint down on power...Turn up the stereo...make more exhaust noises...and send that ****
Old May 24, 2023 | 12:20 PM
Maximus881's Avatar
Maximus881
I recorded another video with higher engine rpm:
https://youtube.com/shorts/cIxl4sCC2Oc?feature=share
Old May 24, 2023 | 09:21 PM
666lisa's Avatar
666lisa
Well considering u revving it and nothing breaking i would say its fine and just enjoy the car.
Old May 24, 2023 | 09:40 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
My 99 made similar noises with headers, I have been told that it is normal and nothing to worry about. Regularly change your oil with Amsoi/M1 or equivalent full synthetic 5W30 (for me twice per year) and enjoy!
Old Jun 17, 2023 | 05:52 PM
dainon's Avatar
dainon
I posted on your YouTube channel as well. Just last week, I had the following upgrades made to my car:
AFR 215 heads
BTR Stage 3 cam with dual coil springs, titanium retainers, and hardened pushrods
1.7 BTR trunions
Melling high volume oil pump
LS2 dual roller timing kit
LS3 head gaskets
My car is making very similar sounds. I don't remember it doing that while it was on the dyno getting the crap kicked out of it. However, on the way home (about a 15 mile leisurely drive), it started to make these sounds. At first, I thought it was clutch chatter, as I had a new Exedy stage 1 clutch put in at the same time. But today I realize it is coming mostly from bank 2 and probably about number 6. I have put about 120 miles on it, and it is running fine, just annoying, especially in the cabin at about 1800-2000 RPM in 3rd and 4th gear. I have a convertible, so it is quite a distraction for the awesome cam sounds and exhaust.
I have read from others here that they switched from the GM recommended 5-30W Mobil 1 to 10-40W to help. I don't know if this works, but I am planning on taking the car back to the shop next week to have them check it out,
Old Jun 23, 2023 | 08:55 PM
KOZ's Avatar
KOZ
**wants a modded car to be like a DD**
Old Jun 24, 2023 | 12:39 PM
Prop Joe's Avatar
Prop Joe
If you take off the valve covers to check push rod length, take a good look at those Comp rocker arms. There is been reports of premature trunnion wear when used on higher lift cams like your .600/.611 your running plus you have higher spring rates with those dual springs. Google it, its a known issue on these LS engines. Best to look before there is metal going through your engine. Get a magnetic drain plug for your oil. I like these as they have super strong magnets:
https://goldplug.com/resources/
https://goldplug.com/shop/ap04/
Old Jul 5, 2023 | 03:14 PM
dainon's Avatar
dainon
I called BTR on Monday and spoke with them about these sounds. They indicated the pushrods are likely 25 or 50 thousands too short, thus opening the valve late and closing it early. It also more than likely indicates vertical play between the pushrod and rocker itself. They said the 1.7 rocker they design is engineered to perform like an LS7 rocker. LS7's don't tick when they run. The noise is caused by the pushrod not staying in contact with the rocker throughout the entire revolution, so when the two impact each other when the lobe is high enough to make the contact, it causes the tick.
It has nothing to do with being a daily driver, it has everything to do with the valve train being right.
Old Jul 5, 2023 | 04:15 PM
Prop Joe's Avatar
Prop Joe
With a normal lifter you need 1/2 to 1 & 1/2 turns on the rocker arm bolt from the zero lash point. you need the plunger in the lifter slightly compressed, not loose and not bottomed out. The check valving inside the lifter will make it happy once there is oil supplied when running. Some are short travel like a Johnson lifter. You never mentioned which lifter you are running. This is a great explanation video:
Old Jul 5, 2023 | 05:19 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Old Jul 6, 2023 | 12:43 AM
vette4fl's Avatar
vette4fl
5 weeks later…
Old Jul 6, 2023 | 07:58 PM
grinder11's Avatar
grinder11
Originally Posted by vette4fl
5 weeks later…
@Maximus881 , it'd be nice to know what happened, if anything.....
Old Jul 7, 2023 | 02:08 AM
Maximus881's Avatar
Maximus881
Everything in the car is as it should be. There are no problems and the length is ok. This is its nature with modifications
To Ticking after modifications LS1
Old Jul 7, 2023 | 07:51 AM
grinder11's Avatar
grinder11
Glad it worked out!!
Old Jul 7, 2023 | 03:56 PM
dainon's Avatar
dainon
So you measured the lengths at zero lash, and all was well?
I had my shop measure mine yesterday, and they were off a hundred thousandths. Ordered some 7.5 pushrods today. Hope to lose my sewing machine racket when it is over.
Old Jul 8, 2023 | 10:48 AM
grinder11's Avatar
grinder11
If you have an issue obtaining the PRs, PM me. I have some Smith Bros. 7.5s.....
