Need advice passing emmissions.
Old May 23, 2023 | 10:39 PM
Markolc1981's Avatar
Markolc1981
Default Need advice passing emmissions.
Hi folks. So I bought a '99 FRC C5 last month from out of state, I currently live in CT. Because it's from out of state, I need to pass emmissions. This will be the final time in this state my C5 needs to pass emmssions, as they will not test cars 25 years old or older. The car is stock, has all the smog stuff still on it, but it does have LG LT headers, X pipe and high flow cats. I'm getting P0420 and P0430 - Catalyst system below threshold. This is highly likely due to the Hi-flow cats.
What would your advice be?
I'm not opposed to getting a tuner to tune out the codes, but I'm not sure if that on its own will cause me to fail CT emmissions. As far as I know, the ECM has never been touched.
Old May 24, 2023 | 12:41 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Ask me about the AIR system tomorrow - separate topic.
If you have an emissions specific code thrown, I don't *believe it will pass until it clears and can be checked off.
They will also fail for general failed codes. Some of those can be disabled with a tuner so they do not post a CEL. They still exist, just no CEL. So running a supercharged car on a speed density tune I would have my MAF throwing a CEL because it did not exist and was not plugged in and therefore gave no signal to the ECU. The factory ECU when it has no MAF signal kicks into speed density and that is how you get that to work. So I ran it that way and had the specific code thrown set to not trip a CEL.
As offered above, I don't believe this code can be simply turned off and get you to pass because of its emissions status. I could also be wrong as this isn't my strong suit. I should also remind that any change in tune requires about a week of driving before all the required emissions checks are completed and you are allowed to test for emissions. You will automatically fail if you go in before the checks have completed their X number of starts / heat cycles / time under X speed, etc.
Old May 24, 2023 | 08:12 AM
averagejoesautos's Avatar
averagejoesautos
I'm not opposed to getting a tuner to tune out the codes, but I'm not sure if that on its own will cause me to fail CT emissions. As far as I know, the ECM has never been touched.
Always the risk when an out of state car that needs emissions. I too live in a state with emissions every two years on cars under 25 years old so I feel your pain. Here in Virginia, we have two routes...fix the issue No lights and no codes = Pass on OBDII only test. The second is more costly...to be granted an emissions waiver. In essence, emissions related diagnostic and repair charges must meet or exceed the cost of the waiver ($965) to be granted a waiver. So basically, you have to pay $1,000 to find or attempt to repair the issue before they will grant the waiver. In your case, it may be worth it if your state has something like this as it will be the last time it has to go through emissions.
Are the o2 sensor in their stock locations? I know my 2004 has four 2 pre-cat 2 post and I know with headers and x pipe install some kits don't utilize the rear two o2 sensors and they must be coded out [hence the for OFF ROAD USE ONLY warning on all those kits] lol. I presume if they did hearders...they also did the mid pipe with an x pipe. if so, you may have two o2 sensor tucked up somewhere.
Joe
Old May 24, 2023 | 08:20 AM
Markolc1981
All 4 O2s are in the stream and hooked up. Because of the LT headers and mid pipe, everything is further downstream of course.
Old May 24, 2023 | 09:27 AM
averagejoesautos
Ok well that rules that out. low catalyst system efficiency is a hard one to diagnose. In essence, the code is saying that the o2 sensors are sensing the same in the pre as they are in the post sensors [which is obviously bad as that means the cat aint doing **** noxious gas wise]. You could be on to something with the hi-flo cats, but a cat is a cat is a cat. It either reduces noxious gas or it dosnt [i.e. the CEL]. o2 sensors are known to go bad from time to time. While a pain in the ***...maybe swapping the REAR ones out first and seeing if that takes care of your problem. I hate shot gunning parts with a smoking gun, but thats easier then changing the cats [depending on how they are attached in your case].
If you have access to a scanner, maybe you can check the live data on the o2 values.
Joe
Old May 24, 2023 | 10:10 AM
Fast one's Avatar
Fast one
Those codes are generated by the downstream O2 sensors and mean the converters don't flow 100%, this causes the check engine light to come on. Several fixes are seen on Youtube, one is to add Cataclean to the gas tank another is to use 18 mm sparkplug antifoulers to space the downstream O2 sensors out from the exhaust flow. The one I used is to tune out the downflow O2 sensors. After the codes are erased and the check engine light is off, the GM driving cycle needs to be run at least once to make the readiness monitors reset. Most code readers will show the status of the readiness monitors which need to be ready to pass inspections.
Old May 24, 2023 | 10:14 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Does CT just look for codes or do they actually put a "sniffer" up the tail pipe?
Old May 24, 2023 | 11:12 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
As of 2021, (When I moved from CT to TX), they just plug into the OBD2 Port and look for Emissions Not Ready Flags, CELs ND DTCS. NO SNIFFERS! )
i
Old May 24, 2023 | 11:31 AM
Missileboy's Avatar
Missileboy
i
Same here in MD, took my 02 in last March and they just plugged in the ODBII and ran the report. They have a sniffer hanging on the wall, but I haven't seen them use it. For 2005 and newer, they added a self service Kiosk station outside where you just drive up and plug in and do your own test. once the vette hits 25, don't have to do it anymore, based on the current rules anyway.
Old May 24, 2023 | 12:59 PM
Tusc's Avatar
Tusc
Would the computer be happy if the rear O2s were simply run not in the pipes but clipped up somewhere in fresh air? My Z06 came to me that way and it passed CT emissions without my knowing, and without cats at all apparently. I didn't know, just went through emissions. I don't know what was or was not altered in the ECU
Old Jun 5, 2023 | 11:47 PM
Markolc1981
Well I passed emmissions. Found an O2 spacer for a few bucks and it worked! I highly recommend if you're getting P0420 and/or P0430. In my case I do have hi-flow cats, but the downstream O2s are kinda far down stream, like at the tail end of the tunnel plate far, nearly a foot away from the Cats.
Thanks for all the advice guys! It's rare that the first and cheapest solution is the one that works!
Old Jun 6, 2023 | 12:11 AM
Tusc's Avatar
Tusc
I found this educational. I never would have thought to use a spacer. I was surprised that the Z06 passed when I bought it because I went through without ever getting under the car and only after passing did I realize that the prior owners had NO cats and had mounted the rear sensors to the heat shields with clips up and out of the way and/or maybe disabled them in the tune.
Oddly, my build is going to be far more emissions compliant than how I received it.
Old Jun 6, 2023 | 11:15 AM
averagejoesautos
So it did end up being the rears as I thought. Well...cheap, relatively easy, and achieved the goal of a PASS!!! Enjoy your win my friend
Old Jun 6, 2023 | 04:31 PM
wrmiles's Avatar
wrmiles
Move to Idaho. No emissions checks or tests.
Old Jun 9, 2023 | 11:49 AM
RonSSNova's Avatar
RonSSNova
Good job. The spacers get the sensor out of the flow so they read different than the fronts. Makes the ECU happy!
I passed yesterday in Oregon. It always passes because I tell it to. It’s always nervous time because it obviously doesn’t sound stock, and it stinks.
So this time they get the mirror on a stick out….two different guys. Even saw them wipe down the sniffer. But didn’t use it. I was sweating for sure.
It has what look like cats on it, and of course it’s very hard to see under being lowered a bit.
They passed me.
Next time it’s 25 years old and eligible for special purpose plates. YES!
Old Jun 13, 2023 | 03:21 PM
lionelhutz's Avatar
lionelhutz
FYI, turning off all the codes for the rear O2 sensors and catalyst systems that they monitor will automatically set the catalyst tests to passed, and of course keep any O2 codes from turning on the CEL or being reported. Same applies to the AIR system.
Once you turn-off the codes the associated monitors are ready right away. I did it to my car and would be able to test it after about 10 minutes of driving.
Old Jun 13, 2023 | 05:53 PM
Tusc's Avatar
Tusc
That's a good piece to know!
To Need advice passing emmissions.
