My battery died
Old Jun 2, 2023 | 07:56 PM
grinder11's Avatar
grinder11
Originally Posted by 4show
thanks for the info. The battery that died was a size 78, so I shouldn’t have any problems with the fit. As for the GM battery, I see it costs almost $100 more than Everstart, Duracell, Exide, Bosch. AGM batteries.
I have had the best luck with genuine AC/Delco batteries. I've had them last up to 7 years!! However, that was before I spent 6 months of the year in Florida. Batteries, Hell, ANYTHING electric, hates heat. So, I think my batteries lasting for 7 years is a thing of the past!
Old Jun 2, 2023 | 08:03 PM
grinder11's Avatar
grinder11
Originally Posted by bookyoh
Just a suggestion - It sounds like you are not comfortable with doing the work yourself. While a battery replacement is a pretty straight forward job, you do need a few tools and some basic knowledge. Perhaps consider buying a battery from a place like Pep Boys who will install it for you. The brand of battery is not all that critical and any name brand 78 battery will likely serve you well for years.
It is straightforward on a C5. Newer cars are another story entirely!! I wont get started (no pun intended.......
Old Jun 7, 2023 | 07:44 AM
4show's Avatar
4show
ok lastly.. can I still use my battery tender jr trickle charger on a AGM battery???
Old Jun 7, 2023 | 09:32 AM
bookyoh's Avatar
bookyoh
Perhaps contact Battery Tender and check:
https://www.batterytender.com/junior
Old Jun 7, 2023 | 10:12 AM
4show's Avatar
4show
specs say AGM compatible:
