Bad oil pan gasket?
Been getting these spots under my 03 lately. The picture was taken from roughly where the driver seat would be.
Would I be correct in assuming it’s possibly a bad oil pan gasket? I’ve noticed a “hot” smell lately too (not a burning rubber or antifreeze smell). Could that be the synthetic oil burning off on the hot engine?
Any idea (ball park) what it would cost to fix?
I had a front timing chain cover dampener seal go bad. (They get hard and cut a grove into the dampener sealing surface) I had engine oil from the front of the engine to the differential. Talk about smell and SMOKE! WHEW!
Here are several things I recommend doing> As FAST one & C5MSG2004Vert stated, get under the car, CLEAN IT Brake parts cleaner and some rags/shop towels will get it clean and dry!, Then drive it a short distance and fix what is leaking. If you don't pin point the leaks, you can guess/speculate all day.
Add a quality seal swell additive to a fresh oil change. If the seals are a little hard & worn, it will allow them to soften and seal the leak.
If you actually do have a pan to block leak, Re torque the UPPER oil pan to block bolts. They have been known to loosen and allow oil to leak out.
NOTE-1 CAUTION! The rear two M6 pan bolts that screw into the rear cover STRIP VERY EASY! Only snug those up lightly!!! If you have a removable lower bat wing cover on the bottom of the oil pan, those little screws strip out easily also. 106 INCH POUNDSis the spec ! I wouldn't go much over 50 in/lbs. Especially if the screw threads are oil contaminated.
The Oil filter/oil temp housing on the side of the block can also leak. .
Yep, That Oil Pressure Sensor on the back of the block is a very common leak issue! Get a flashlight and an inspection mirror and inspect it for leaking oil. It leaks out of the body of the sensor.
Give it a good cleaning and inspection.
BC
I’ve kept an eye on the oil level and it’s not moving much, so the leaks can’t be that bad. Oil level is currently just a little bit below the midpoint on the dipstick so that means it’s got the required 6.5 quarts.
Adding a quart of Lucas would obviously bring the overall level to 7.5 quarts.
Is that too much for normal driving?
All the usual suspects have been mentioned already. You didn't mention your mileage but, add valve cover gaskets to your list of inspection items. If you can smell a whiff of burning oil, it means its contact exhaust. Small leaks are sometimes hard to track down as oil is a viscous substance that like to move about freely
BC
