AC electrical problem
Old Jun 8, 2023 | 06:58 AM
NOsburn's Avatar
NOsburn
Default AC electrical problem
Recently my AC dash panel goes dead when I first start my car. After about two minutes it comes on and works fine. It puts out great AC once it kicks in!
Any ideas what to look at?
Old Jun 8, 2023 | 03:15 PM
redzg's Avatar
redzg
Dual control system? The panel shows no lights, and there is no fan or anything else going on when 'dead', yes? Not just the typical too dim to read cutting in and out? I'd be suspicious of a bad ground. There has been a pretty in depth thread on the system recently with much good input from C5_Diag and UselessC5. Considerable troubleshooting and several wiring diagrams:
https://www.corvetteforum.com/forums...ermittent.html
Old Jun 8, 2023 | 05:41 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
First off what year is the car ??...your profile shows a 1979 ??...can you edit your profile so we know what we're dealing with...using the DIC see if you have any HVAC or any codes stored...if you see a U code relating to the HVAC (HVAC No Comm) it may be a power or ground issue....do you have any other components inop like your rear window defogger or inside rear view mirror ??
Old Jun 8, 2023 | 11:49 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YEP,, Read and post ALL your DTCs. You have to figure out if the unit is getting the PROPER POWER to the head unit. Just like C5 Diag stated, Our C5 have issues that can cause problems to be seen in numerous other modules or parts of the car caused by ONE THING..
Seeing how you know that you are having a problem with your HVAC, you can get a Multimeter and find the FUSE for the HVAC Module. It will be in the Passengers Footwell Fuse box. When you experience the issue with the HVAC being dead, measure the HVAC Fuse voltage.
On top of each fuse are two small test points. Turn the ignition switch to ON and measure BOTH test ports to a known GOOD Chassis ground.
Both test points should read FULL BATTERY VOLTAGE to ground. If you see something LESS that full battery voltage, post up the voltage that you see and we will point you in the correct direction.
Bill
To AC electrical problem
