I have a mild problem with my 2000 Base convertible. After a period of time driving I find that the Oil drain bolt slightly loosens. This causes a slight dripping of oil enough to mess up the bottom of the engine, I notice this most when some of the oil hits the catalytic converter. Never enough to show shortage on dip stick. I attribute this to the dissimilar metals aluminum pan and steel bolt having different rates of heat expansion and cooling rates.
My question is is it wise to use some Teflon tape on the bolt to maybe mitigate this problem?
I do not believe the threads are bad as I have no problems torquing the drain bolt to spec. Do you use a crush washer with the bolts that have the inlaid rubber?
Look at the face of the oil pan where the rubber on the drain plug seats/seals against.
It has to be smooth and flat. It may have a burr or some scoring. FIRST, try a new GM Oil Pan Bolt but make sure that the seating surface on the pan is able to seal against the rubber seal on the Drain Plug. I would NOT use Teflon tape or a washer. The rubber inlayed seal on the drain Plug is actually what seals.
Looks like the bottom of that pan took a pretty good digger. Are you sure its not cracked and leaking from that damage?
Clean it well and inspect that area for a crack..
Thanks for your response. The pan and bolt on my car look in excellent condition, a little oil sprayed around but that is all, never enough oil to show being low on dip stick. I do believe that my using a crush washer is the problem, will see on next oil change coming up very soon.
If the oil pan drain bolt rubber ring is not smooth, soft and pliable, replace the bolt with a new one which has a new rubber ring.
I ALWAYS seal all my oil drain bolt threads with a bit of silicone sealant. No drips and even if you forget to tighten it, will not fall out on its own.
Yes, the next oil drain you have to remove the old sealant from the bolt.
You do know the rubber insert in the drain bolt is replaceable, right? And you need to replace it occasionally. I do it every change, but I don't think I need to.
Pretty commonly available - I presume most any auto parts store would have them. I ordered a bunch online once - I have more than enough for the rest of my life!
Advisable to avoid Teflon tape on oil fittings/plugs. Any of that tape falls off inside could cause a blockage. Best to use an oil rated thread sealer. 👍
As long as you're changing the oil drain plug, why not get a magnetic drain plug? I bought one a few years ago, from Ecklers(?). Anyway, it has a pretty strong magnet on it. I mean, as long as you'll have the old one out, you're there anyway. Try to get one with a rare earth magnet. I agree about Teflon tape causing issues. When we used it years ago on our transmission test stands, there would sometimes be a small piece that comes off, and would lodge in the valve body, which would screw up the calibrations. We changed to Loctite white Teflon liquid pipe sealant, which worked great, as long as you didn't gob the fitting with enough to frost a cupcake!! Worked perfect. End of problems.....
