Z51 vs F45
Old Jan 18, 2003 | 01:04 AM
Rob K's Avatar
Rob K
Default Z51 vs F45
I know the Z51 is set up better for racing, but would a C5 with Z51 out handle a C5 with F45 on a skid pad, or would be identical?
Thanks!
:cheers:
Old Jan 18, 2003 | 01:13 AM
Mordenkanen's Avatar
Mordenkanen
Default Re: Z51 vs F45 (Rob K)
I don't know Someone will :seeya
Old Jan 18, 2003 | 01:25 AM
DsC5's Avatar
DsC5
I think F45 has the base sway bars, etc., so the z51 would outhandle it. :seeya
Old Jan 18, 2003 | 05:09 AM
EHS's Avatar
EHS
Default Re: Z51 vs F45 (DsC5)
Why?
Having said that, roll stiffness is not the sole determining factor in a steady state handling comparison, which is what the skid pad is.
Old Jan 18, 2003 | 08:59 AM
ifeeltheneedforspeed's Avatar
Default Re: Z51 vs F45 (EHS)
Thicker sway bars tend to increase cornering g-loads, if all else is equal.
Old Jan 18, 2003 | 09:25 AM
Default Re: Z51 vs F45 (ifeeltheneedforspeed)
I hate it when people make a statement and don't explain the rational, like I just did.
Thicker sway bars reduce the angle of roll of the vehicle. Less vehicle roll reduces the effect of positive camber of the tire patch to the road during cornering. Also, more roll will compress the springs and can result negative handling characteristics.
One statement that GM made about why they increased the rear spring rate on the zo6 was that excessive spring compression while accelerating hard out of a corner led to a bottoming out of the spring which will result in oversteer because of the sudden increase of spring stiffness when it hits the bump stops.
Not only are the z51 and zo6 sway bars thicker than the f45, but the springs are stiffer as well. Both of these will reduce the angle of body roll.
Old Jan 19, 2003 | 12:12 AM
DsC5's Avatar
DsC5
Why?
well, assuming my original presumption is correct (that the F45 has the base sway bars, etc.) I am almost certain this is true, then the Z51 "Performance Handling Package" should in theory outhandle the F45. Thicker sway bars and different shocks should make a marked improvement in handling. Will it outperform it in every single objective measurement? I honestly don't know. :confused: Perhaps on the skidpad measurement alone, the F45 would top the Z51, but I would doubt it. I'd bet that it is safe to say that a Z51 car will outhandle a F45 car in most every respect. After all - that is the point of Z51 - to be the highest non-Z06 handling package for C5s.
To make my initial statement more precise, we could say:
"I think F45 has the base sway bars, etc., so the z51 should outhandle it. :seeya"
Someone please correct me if I'm wrong. :seeya
[Modified by DsC5, 12:16 AM 1/19/2003]
Old Jan 23, 2003 | 08:53 PM
MY Vette's Avatar
MY Vette
Just my .02....you'd have to wonder why the F45 option costs way more than the Z-51 then, right? Sheeese, I dunno.... :confused:
Old Jan 23, 2003 | 11:19 PM
kmcls1's Avatar
kmcls1
Default Re: Z51 vs F45 (MY Vette)
Here is my .02 worth. My '98 has the F45. Yes, the sway bars are standard. From what I have been told (and have not tried..YET) is to install the Z51 sway bars on the car, supposedly this is the ultimate setup since you can adjust the suspension and have the benefit of the bigger bars. I have also been told that I can obtain these REALLY cheap from some of the Tuners as Takeoffs..
My father's 2000 has the Z51 and it handles much better than my 98 (am sure that the active handling has a lot to do with this also but...) however I prefer the 98 for a long trip as the smooth ride is nice when not wringing out a mountain road.
If anyone has some Z51 sway bars sitting around, give me a ring...
Ken
Old Jan 23, 2003 | 11:26 PM
jeanlucpicard's Avatar
jeanlucpicard
Well, I have a 2001 convertible that I autocross. I have the F45 suspension and have installed the Z06 front/rear sway bars :steering: - what a difference! The car corners flat and is much more responsive on the course.
My next mod will be to add an 800# front spring and a 560# rear spring from VBP.
Costs - Z06 sway bars + metal end links $265 from Fitchner.
Springs $950 (unless I can get a set off someone)
All in all, I like the F45 with Z06 suspension setup. :hurray:
Save The Wave :cheers: :seeya :cool:
Old Jan 24, 2003 | 04:13 AM
C5 Frederik's Avatar
C5 Frederik
Default Re: Z51 vs F45 (jeanlucpicard)
I´m in the same situation. F45 with Z51 swaybars, looking to upgrade the springs.
Question: how did you get the #´s for the springs? Is there a reason for 800/560? How did you select this?
Frederik
Old Jan 24, 2003 | 07:37 AM
jeanlucpicard
Default Re: Z51 vs F45 (C5 Frederik)
I contacted VBP and discussed my intentions, daily driver car, frequency of autocrossing, desire for ride quality (not rail car but firm while leaving kidneys intact), and so on. We went back and forth for about 2 weeks and the 2 spring rates were agreed upon.
Hope the helps.
SAVE THE WAVE :seeya :cheers: :cool:
Old Jan 24, 2003 | 08:12 AM
PalmettoVetteMan's Avatar
PalmettoVetteMan
do the '02's come with aluminum endlinks as standard equipment? i assumed that they did when I ordered the Z-51 bars from Fichtner.
since the Z-51 bars are larger in diameter than stock, wouldn't we need a different insulator?
also, are there different insulator material options? maybe polyurethane or something like that. :confused:
Old Jan 24, 2003 | 09:40 AM
fdxpilot's Avatar
fdxpilot
The F45 is the 1st generation adjustable suspension, so you're paying for electronics and special adjustable shocks. As mentioned, the springs and swaybars are all base suspension pieces. Supposedly, the F55 on 3003s is a quantum leap above the F45 and might actually be preferable to the Z51. But given the choice on a pre 03 car, I went with the Z51.
Old Jan 24, 2003 | 10:36 AM
EHS's Avatar
EHS
Default Re: Z51 vs F45 (kmcls1)
Ken
I have a spare Z51 front bar (replaced that on my F45 car with a thicker Z06 bar).
Old Jan 24, 2003 | 12:46 PM
PalmettoVetteMan
Correction....I ordered the Z-06 bars from fichtner, not the Z51. Sorry :crazy:
Old Jan 24, 2003 | 04:14 PM
EHS's Avatar
EHS
Default Re: Z51 vs F45 (PalmettoVetteMan)
The end links are extra to the bars.
Bushings come with the bars.
To Z51 vs F45
Old Jan 24, 2003 | 04:26 PM
jeanlucpicard
Actually, PalmettoVetteman, your comment is not necessarily accurate. My Z06 bars from Ken Fitchner Chevrolet was a kit that included the front and rear sway bars, bushings AND metal end links. So the end links are not extra if you purchase the GM kit. Ken sells the whole enchilada for around $270 delivered to your doorstep! Ken is great.
Old Jan 24, 2003 | 04:27 PM
jeanlucpicard
OOOpppsss..... Sorry Vetteman, should have been EHS. Got my replies crossed.
Old Jan 24, 2003 | 06:25 PM
EHS's Avatar
EHS
Well, John, ...
my "kit" from Bob Wendorff, Director of Parts and the General Universe of Fichtner Chevrolet, purchased in 2000, included the Z51 bars with the bushings, AND WITHOUT THE ENDLINKS. I paid extra for mine.
The thread was about the Z51 parts, not the Z06. I note that the Z06 parts package comes with the endlinks.
Your results may have varied. OOOpppsss.....
[Modified by EHS, 6:28 PM 1/24/2003]
