Column Lock Bypass worked for 4 days - next?
Old Jun 13, 2023 | 07:53 PM
billla's Avatar
billla
St. Jude Donor '14
Default Column Lock Bypass worked for 4 days - next?
I had a "Service Column Lock" message so installed a Column Lock Bypass. Pretty straightforward process, and following installation the message went away. 4 days later, it's back.
What's next to troubleshoot? Could the CLB have failed? Is there a way to test it?
Old Jun 13, 2023 | 08:06 PM
Dads2kconvertible's Avatar
Dads2kconvertible
I'd start with an email to tech support for whatever bypass you used.
They will probably want something more specific than 'message came back'. Any FAQs at their website?
Old Jun 15, 2023 | 01:37 PM
wrmiles's Avatar
wrmiles
LMC5. Do a search.
Old Jun 15, 2023 | 02:01 PM
yellow2007's Avatar
yellow2007
I've heard that there's a "brown wire mod" to go with this kit. I think it depends on year and if auto or six speed
Old Jun 15, 2023 | 07:05 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Just do the Brown wire mod as long as you are working the project. It hurts nothing if you do it.
Old Jun 20, 2023 | 02:13 PM
billla's Avatar
billla
St. Jude Donor '14
Talking with Richard at Compliance Parts, the two common causes for this are a low battery or leaving your key in the ignition after the BCM goes to sleep.
The battery is strong, but I do sometimes turn off the car and leave the key in - so I'm going to reset it again by removing the negative battery terminal for 2 minutes and NOT leaving the key in the ignition after turning off the car. We'll see what happens.
To Column Lock Bypass worked for 4 days - next?
