Weld Titanium Exhaust
Old Jan 18, 2003 | 09:43 AM
01c5z06's Avatar
01c5z06
Default Weld Titanium Exhaust
Can our Titanium exhausts be welded?? One of mine was cut when I put my Borla on.
Old Jan 18, 2003 | 11:00 AM
Bill Reid's Avatar
Bill Reid
Default Re: Weld Titanium Exhaust (01c5z06)
Titanium is not easily welded... certain conditions must be in place. To find somebody that welds titanium will be much more difficult than somebody who, say, welds aluminum... and does a good job.
Old Jan 18, 2003 | 04:34 PM
kenrobb's Avatar
kenrobb
You can find all sorts of info on a google search for welding TI. It appears that a lot of bike frames are TI. So maybe a bike shop can be a lead. Here's a link to a frame manuf. article I found. http://www.sevencycles.com/technology/techwelding.html
Old Jan 18, 2003 | 09:28 PM
Kenny94945's Avatar
Kenny94945
Yes it can.
However, finding one with his experience may not be so easy.
Motorcycle racers are a good start.
The trick....to my understanding is to creat a shield from oxygen. This can be done with a tent. As our other co-member stated an internet search on welding Ti will be of great benefit. Additionally, filling the exhaust with Argon gas before welding is another trick of the trade.
Old Jan 18, 2003 | 11:09 PM
MRWHOOPPEE's Avatar
MRWHOOPPEE
Default Re: Weld Titanium Exhaust (Kenny94945)
should be TIG welded :cheers:
Old Jan 19, 2003 | 02:25 AM
illmac77's Avatar
illmac77
CI 7-8 Veteran
CI 8 Car Show Winner
St. Jude Donor '07
Default Re: Weld Titanium Exhaust (MRWHOOPPEE)
kenny's got it right. it needs to be shieled and have a back flow of argon, the only way that i know of is tig welding it, i've done some titanium welding when i went to weld school and it was the hardest type of metal that ive every tried just for the fact that everything the had to be in perfect conditions. other wise the weld isnt going to happen, the only other metal that was almost as dificullt was magniesium. im sure youll be able to fing someone with a little searching
Old Jan 19, 2003 | 01:52 PM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
If you are talking about the mid pipe (the part with the cats and h-pipe) it is not titanium.
If you are talking about the over the axle pipes and mufflers they are titanium
To Weld Titanium Exhaust
