O2 sensor adapter for P0133
Additionally, from my research I have also found that people say if you use downstream O2 sensors in the upstream position this mitigates it slightly due to the better heating circuit and they are more sensitive.
The problem I am having is that I cannot find the adapters to install downstream O2 sensors in the front. My 04 ZO6 has square for front and back, just one is female and the other male so you cannot hook them up backwards. The only adapter I am finding is from flat to square which will not work in my application. I can rewire the new O2 sensor to make it work, but since the pins are different (male vs female) this may be a pain.
Has anyone found an adapter for this? If so could you help a brother out???
Thanks in advance!
