Original Engine?
Old Jul 2, 2023 | 08:58 PM
ChopperLoco's Avatar
ChopperLoco
Default Original Engine?
So i'm curious,my new to me 01 Z has 150k miles and runs very well so far,how could I check if it still has the original engine in it?
It is stock looking externally.
Dom
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
edit: nvm
Old Jul 3, 2023 | 09:30 AM
LowcountryVette's Avatar
LowcountryVette
You can verify it has the right parts such as 5.7 casted on block, 243 on the heads etc…
Dont know of a way you could tell for certain it is original. At only 150k miles there’s no reason it shouldn’t be original though unless it was abused or swapped for something better.
Old Jul 3, 2023 | 10:39 AM
Prop Joe's Avatar
Prop Joe
I'm not sure how you would know if the engine was replaced with the correct replacement. You may want to take a peak inside the valve covers and make sure you don't have the dreaded yellow springs... There was just a failure a month or so ago. I donated my old blue ones to help the young mans cause.
https://www.corvetteforum.com/forums...-cylinder.html
Yellow springs:
https://www.corvetteforum.com/forums...ilures-29.html
I'd run it till the wheels fall off...
https://www.corvettemuseum.org/high-...vette-donated/
Old Jul 3, 2023 | 12:00 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
Dom
https://www.psiconversion.com/tech/ls_guide/ls6.html
Old Jul 3, 2023 | 12:31 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
https://www.corvetteforum.com/forums...x-engines.html
https://lateral-g.net/forums/showthr...%20the%20block.
Old Jul 3, 2023 | 02:24 PM
ChopperLoco
Thanks everyone!
Dom
To Original Engine?
