Door control module
Old Jul 3, 2023 | 09:02 AM
hogwild2556's Avatar
hogwild2556
Default Door control module
Hi, I have an 01 vert 6 speed. I'm having an issue with the passenger door window and locks. I've checked all the harnesses including the ones in the accordion. I find when the passenger window does not work, I can either unplug the red plug from the module or now I find if I disconnect the battery and reconnect it, everything will work for a short while. I have tried replacing the passenger door module with no success. I'm wondering if it might be the drivers module. Any help would be greatly appreciated.
Old Jul 3, 2023 | 10:50 AM
Dads2kconvertible's Avatar
Dads2kconvertible
You'll probably get more effective assistance if you use your original thread: https://www.corvetteforum.com/forums...cal-issue.html
