C5 Z06 OEM Valve Spring Replacement Questions
Old Jul 14, 2023 | 02:28 PM
csu158's Avatar
csu158
Default C5 Z06 OEM Valve Spring Replacement Questions
I have a friend with a 2002 Z06. It's his daily driver and it has 212,000 miles. The other day he broke an exhaust valve spring. No other damage occurred. He plans to drive this car for a long time, so I told him to replace all the valve springs. The mechanic that replaced the exhaust valve spring told him not to worry about the other valve spring and just deal with it IF one of the other springs break. He said OEM valve springs are not available and aftermarket valve springs are junk and will probably break before the ones that are currently in the engine will. I find that hard to believe. I still say replace all of them now. So two questions:
  1. What would you do?
  2. Which valve spring/brand would you recommend?
Thanks,
Jim
Old Jul 14, 2023 | 02:47 PM
G_Loc's Avatar
G_Loc
He should find a new mechanic.
I would replace them all. BTR SP011 and PAC 1218 beehive valve springs will fit. New OEM springs are readily available, part number is 12713265.
Old Jul 14, 2023 | 04:01 PM
csu158's Avatar
csu158
Thank you!
Old Jul 14, 2023 | 04:17 PM
LowcountryVette's Avatar
LowcountryVette
Old Jul 14, 2023 | 06:16 PM
grinder11's Avatar
grinder11
Thanks,
Jim
Glad I don't know, nor want to know, that mechanic!! You can certainly tell it's not his car!!! At 212,000 miles, if one valve spring broke, others will soon follow. I wonder if the guy that broke the spring realizes how lucky he was?? When a single spring breaks, many times the valve says hello to the piston, and they aren't friendly with each other. Just deal with it when, NOT IF, another spring breaks, eh? Russian roulette, valve spring version. Replace every other valve spring in the engine. As for replacement brand, PAC gets my vote. If you dont know what brand spring the "mechanic" used to replace the broken spring, replace all 16 with PAC's. Deal with it......WOW.
Old Jul 14, 2023 | 07:08 PM
Prop Joe's Avatar
Prop Joe
Was this a yellow spring that broke by chance? Yellow went to the improved Blue, which them went natural steel color in the GM lineup. Change them all. GM, PAC....
Old Jul 14, 2023 | 07:31 PM
csu158's Avatar
csu158
I agree 100%. I tried to explain that to him, but for some reason he thinks his mechanic is great. I showed him this post and I think he’s on board with replacing all the springs now.
One correction to my original post - the mechanic that’s giving him advise is his regular mechanic, but not the one who replaced the spring. He was on his way from Cleveland to Florida when the spring broke, so a service station in the town he was in changed the spring. I don’t know why they didn’t change all of them at that time.
Old Jul 14, 2023 | 07:33 PM
csu158's Avatar
csu158
https://www.youtube.com/watch?v=_gNlgnHdq1o&t=7s
His springs are natural steel color.
Old Jul 15, 2023 | 06:33 PM
grinder11's Avatar
grinder11
Me either. That's like driving with 4 worn out tires, and when one blows, that's the only one you would change. Not my way of doing things....
Old Oct 3, 2023 | 09:46 AM
vito02's Avatar
vito02
I believe an 02 C5Z was originally built with the "yellow" springs? If the broken one is plain finish, does that suggest that the springs had been previously replaced?
If so, does the owner know at what mileage the plain-finish springs were installed?
BTW, I agree: Change them all.
Old Oct 3, 2023 | 06:48 PM
csu158's Avatar
csu158
He bought the car new and no one has replaced the springs until now, so the natural steel colored springs must be original.
Old Oct 3, 2023 | 07:02 PM
vito02's Avatar
vito02
Thank you, csu158.
Do you know, or can you ask your friend, the production date shown on the rear of the driver door?
-V
Old Oct 3, 2023 | 08:16 PM
csu158's Avatar
csu158
You're welcome.
I wish I could, but I'm in Cleveland, OH., his car is stored in Florida, and he is out of the country until the spring. He'll likely be back in Florida towards the end of May. If you'd still like to know at that time, just send me a message to remind me to ask him. Sorry, that's the best I can do.
Old Oct 8, 2023 | 11:25 AM
UstaB-GS549's Avatar
UstaB-GS549
On my 02 Z06 the OEM valve springs were yellow. I replaced them with stock yellow beehive springs in 2009.
Stock replacement spring
Original springs
Old Oct 12, 2023 | 06:44 PM
adairr's Avatar
adairr
3rd Gear
Default Shocks
Help me with the code because i removed select ride shocks, a tech ii is suppose to remove the f55 rpo how is that done?
Old Oct 14, 2023 | 03:00 PM
grinder11's Avatar
grinder11
????????? This thread is about valvesprings-NOT shock absorbers!!! If you want answers to your shock questions, you should start a new thread, instead of hijacking the OP's thread.....
To C5 Z06 OEM Valve Spring Replacement Questions
