Remove Key wait 10 Seconds Problem
Old Jul 14, 2023 | 10:43 PM
98Convertable's Avatar
98Convertable
Default Remove Key wait 10 Seconds Problem
Ok. 1998 c5 with LM5 with brown wire mod.
I still get this message. HOWEVER if I never remove the key from the ignition I will not get the message.
any thoughts?
regards.
Old Jul 15, 2023 | 12:45 AM
jdmvette's Avatar
jdmvette
Night Owl for life
pull LMC5 and put in one of these
Amazon Amazon
i keep seeing posts like yours over and over with LMC5.
i've had a simple column lock bypass module in my car for almost 20 years now without issue.
Old Jul 15, 2023 | 12:52 AM
Smoken1's Avatar
Smoken1
Call Richard st Complance parts he will get you squared away
Old Jul 15, 2023 | 07:17 AM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Take the junk LMC5 out and install the old-school CLB.
You'll never get the "pull key" message. You won't have to "call" Richard. You'll never have to do the brown wire mod.
The CLB just works as it should.
Old Jul 15, 2023 | 09:04 AM
yellow2007's Avatar
yellow2007
https://www.amazon.com/Corvette-Stee...s%2C132&sr=8-5
Amen to that...................
Old Jul 15, 2023 | 12:08 PM
Dads2kconvertible's Avatar
Dads2kconvertible
Note that over 20% of the reviews to the item you posted say it doesn't work and the seller was unresponsive. So apparently neither solution is great.
Old Jul 15, 2023 | 12:25 PM
drTim's Avatar
drTim
I started getting this message a couple of years ago. My 2004 Z06 Commemorative has 131,000 miles on it now. Still like new. However Chevrolet did remove the steering wheel lock on a "recall" years ago. Now to the "10 second message": I defeat it by turning the key ON for about 2 seconds,BUT Before the Warning Displays, then removing the key. I reinsert the key after I remove it and start the car with no problems, after doing that. The engine will run with the Warning ON, BUT it will shut off if you try to drive the car without waiting the 10 seconds. Best Regards, and this solution doesn't cost anything $
Old Jul 15, 2023 | 05:23 PM
Soprano's Avatar
Soprano
I've heard the exact same thing about the CLB. Doesn't always solve the problem.
I've had the harness replaced twice also. The only thing that I noticed is it happened both times when the battery was weak. Make sure you keep a good fresh battery in there and always use a battery tender or automatic charger. Good luck!
Old Jul 17, 2023 | 11:06 AM
Moved to C5 Tech.
Old Jul 17, 2023 | 08:31 PM
Alley Oop's Avatar
Alley Oop
Never had a problem after installing the LMC5.
To Remove Key wait 10 Seconds Problem
