PCV valve replacement frequency?
Old Jul 16, 2023 | 05:10 PM
Alley Oop's Avatar
Alley Oop
Default PCV valve replacement frequency?
I've got a bone stock 2002 Vette, 5.7 litre. It's got just over 50,000 km. I have no history on the car. I bought it at a used car lot (it was mint, I couldn't walk away after I laid my eyes on it) At what interval would you replace the PCV valve?
Thanks in advance.
Old Jul 16, 2023 | 07:58 PM
h8snow's Avatar
h8snow
To me as cheap and important as PCVs are no more that 10000 miles.
Old Jul 16, 2023 | 08:26 PM
2010Pony's Avatar
2010Pony
If you shake it from what I’ve heard and it rattles it’s fine, just saying
Old Jul 17, 2023 | 01:55 AM
h8snow's Avatar
h8snow
They are a metering device that can get partially plugged and still rattle. Replace with only new OEM.
Old Jul 17, 2023 | 07:35 AM
redzg's Avatar
redzg
Not sure if the PCV valve is considered a consumable maintenance part. If it rattles it’s probably good.
Old Jul 17, 2023 | 08:21 PM
Alley Oop's Avatar
Alley Oop
Thanks for the input guys. I'm going to make the PCV valve part of my annual inspection. If it rattles, I'm not replacing it.
Old Jul 18, 2023 | 02:08 PM
sayerbloke's Avatar
sayerbloke
I’ve heard the hose can be brittle so caution when removing the valve!
Old Jul 18, 2023 | 02:40 PM
jcgunn's Avatar
jcgunn
Mine has 128K, seems fine.
Old Jul 19, 2023 | 10:22 AM
Alley Oop's Avatar
Alley Oop
Mine is a 2002, the hoses feel like new and the PCV valve still rattles.
Old Jul 19, 2023 | 10:29 AM
Alley Oop's Avatar
Alley Oop
I can't see any reason to replace it if it still has a healthy rattle.
Old Jul 20, 2023 | 07:57 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
To be on the safe side, yeah, I'd check to see if yours "rattles". As previously mentioned, be careful in handling the hoses, then just spray a small bit of throttle body cleaner into it, let it dry, and you'll be good to go. I'm the original owner of my C-5 (2001), and have a little over 30,000 miles on it. I've removed the PCV valve twice, and hit it with a shot of TB cleaner, both times. It still rattles just fine.
Old Jul 23, 2023 | 05:00 PM
Alley Oop's Avatar
Alley Oop
Thanks. That's the kind of feedback I hoped to hear.
Old Jul 23, 2023 | 08:17 PM
h8snow's Avatar
h8snow
They meter. Rattle means they rattle that's all . One sure way to tell is leaking front or rear main seal. I change mine out @$5.
Old Jul 25, 2023 | 05:34 PM
Alley Oop's Avatar
Alley Oop
I just checked that the PCV hose has vacuum. This was between the PCV valve and the intake manifold. That should mean that the PCV valve not only rattles but is also breathing. While testing for vacuum, the motor runs rough and smooths out as soon as I reconnect the hose.
Looks like it's working like it should. I'm adding a vacuum check to the rattle test.
Old Jul 25, 2023 | 06:26 PM
leadfoot4's Avatar
leadfoot4
To PCV valve replacement frequency?
